L'Amp: A simple SIT Amp
Old 7th March 2013, 03:28 PM   #1631
Garuda77 is offline Garuda77  United Kingdom
Does anyone know what the input impedence of L'amp is? or if it can be varied? I would like to use Lightspeed attenuator in respect of which it is sugested amp has 80kohm or higher impedence.
Thanks Terry
Old 7th March 2013, 03:34 PM   #1632
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
put Jfet buffer in between
L' is having input imp. well bellow R1 ( 47K) and it's too much varying for Lightspeed
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 7th March 2013, 08:11 PM   #1633
juanitox is offline juanitox  France
juanitox's Avatar
i use ldr ( Warpspeed) as passive preamp before the SIT with 27K input and it sounds fine..
but for me the magic comes with a tube stage /LDR combo driving the Sit
French is not a crime.
Old 17th March 2013, 07:48 PM   #1634
DIYspaceW is offline DIYspaceW  Slovenia
Guys, If we would need to design a plate choke specialy made
for 2SK82 what would be the guide lines?
We need usually for 100ohm plate resistance 1H inductance,
so we only need 0.1H here or am I missing something?
The hammond filter choke 193V has 0,3H but is not designed for plate reactor.
Any thoughts?
Old 17th March 2013, 10:06 PM   #1635
Zen Mod's Avatar
even if for toob , it can be useful :
http://vt52.com/diy/tips/platechoke.xls
VT52.com
Old 17th March 2013, 10:34 PM   #1636
woody is offline woody
A quick look at an air core inductor calculator shows ~ 7lbs of #16 magnet wire will
let you have over 100mh of inductance with a resistance of about 3.84 ohms. If you play with the dimensions you can use even less wire but as i said that was just a quick look.
Old 18th March 2013, 09:42 AM   #1637
Ok...
Old 19th March 2013, 04:35 PM   #1638
juanitox's Avatar
is going parafeed output with the SITAMP will work ? let say we use 130mh
hammond choke what kind of transformer could do the job as parafeed load ?
Old 19th March 2013, 04:50 PM   #1639
I am working on a SIT parafeed...It sounds nice, I mean the words...SIT PARAFEED
You wont find a 20-30ohm primary and 10-15W output transformer to use as a parafeed.
I will use higher voltages to be able to use a 50ohm output transformer.
This is an expensive project so far, but will see how it performs. Its an experiment...
Old 19th March 2013, 05:26 PM   #1640
flg is offline flg  United States
flg's Avatar
Have you talked with these guy's???
Autoformers offered by ZeroImpedance- Improve your speaker sound quality with the use of an autoformer.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
