L'Amp: A simple SIT Amp
Old 9th February 2013, 11:56 PM   #1621
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
L'Amp: A simple SIT Amp Send a message via Yahoo to vdi_nenna
I'm sure it's very fine.
I build, therefore I am.
Old 12th February 2013, 02:30 PM   #1622
Dzius is offline Dzius  Poland
Dzius's Avatar
Are there any other suggestions for operating point for 8ohm load other than below?
Juanitox wrote:
"1.6amp 19V with inductor
or at 14V 2.4amp with res load"
Michael Rothacher wrote:
"19-20V across the SIT @ 1.55-1.6A " - IXTH6N50D2 Constant Current Source
Old 12th February 2013, 06:30 PM   #1623
juanitox is offline juanitox  France
juanitox's Avatar
i have made some test with a 10ohm reosthat bypassed with a 47000uf
and looking at the loadline it's difficult to find a bad operating points .. or the best one if you don't have a distorsion analyzer .. at this time i run mine at 16V 2.13A with a 1.8R source resistance and 47000uf bypass.
French is not a crime.
Old 26th February 2013, 07:34 PM   #1624
bluewater is offline bluewater  United States
Is there a simple diy preamplifier that could drive the L'Amp?
Old 26th February 2013, 08:41 PM   #1625
vdi_nenna's Avatar
BOZ-J drives my SIT-CCS L'amp. Mike Rothacher is coming out with a companion preamp for the L'amp, but that preamp might be a few months out.
See his site for more info.
Old 27th February 2013, 02:12 PM   #1626
I'll look into that. Thank you
Old 27th February 2013, 03:02 PM   #1627
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Cool Pre-amp for LĀmp...
Hi Bluewater!
I run mine LĀmp with the Passive B1 - and now that my Alp12P is finished - the soundpressure and revelation from the sources is magnificent. Really enough for my 35sq-meter room.
Best
Olav
Old 27th February 2013, 04:59 PM   #1628
Hi Olav,
I do have the B1 but I unfortunately only a 2v source. I do plan on bi-amping my BassZillas with two paralleled B1's. With little gain from L'Amp I think it would be good to give the source output a boost.
Eric
Old 27th February 2013, 07:29 PM   #1629
OlavHaal's Avatar
Default Hi Eric
Earlier I used my B1 with the LĀmp - and the Alp10.2(which is about 89 db). The source was then the DirectDac(SC4398) which gives about 1,75 volt output!
on some recordings it could be somewhat low output - but mostly very good. Today I have the Alp12P - and I have installed Sowthers on the balanced output on the Dac(so it should give approximately 2,5 Volt output). The same configuration on the LĀmp and....
So today it very good and strong output!
Best
Olav
Old 27th February 2013, 11:27 PM   #1630
Hi Olav,
I'll definitely give it a try with the B1 alone. I've just about collected all the parts for my L'Amp. I'm going almost exactly by Michaels Inductor version. I'm only waiting for Antek to make the AS-4428 available. They said some time in mid April.
Eric
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
