Old 13th January 2013, 09:59 AM   #1591
juanitox's Avatar
Originally Posted by Telstar View Post
Noo don't give up!
no even i run mine without input cap and with a bypassed source resistor .. none of my ancient SET had sounded like this Sit amp..
put a tube buffer before and you 've got a Big Fat SET sounds , or just a low impedance passive device before ( LDR on my side) and you have a very refined and neutral sounds but lacking some extended bandwitch and low level detail
nothing is perfect in this world .... and that's why i love to play
French is not a crime.
Old 13th January 2013, 12:09 PM   #1592
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
if your tube buffer is giving change to big fat SE sound , then that's no good buffer , in my book
any iteration of SLCF is way to go ; in short - cascode up for constant voltage mode , CCS down for symmetrical and benign THD spectra
it doesn't matter will you make it with toobz , sand , cork , whatever
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 13th January 2013, 12:47 PM   #1593
Zen Mod's Avatar
regarding some private correspondence with RK R , about grades ;
I hope someone is having exact grade tables ?
sorry if that's already posted
File Type: jpg Sony HiFi SB49 TA-4650 & 5650 Page 1.jpg (87.1 KB, 338 views)
File Type: jpg Sony HiFi SB49 TA-4650 & 5650 Page 2.jpg (97.4 KB, 327 views)
Old 13th January 2013, 02:03 PM   #1594
Telstar is offline Telstar  Italy
For fun today with a friend i measured the resistance of my four K82 and two of them where nicely close with about 3,5 Ohm. Looking good
The hardest thing is to procure the ixys fets, if someone has spares, please sell me.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 20th January 2013, 01:58 AM   #1595
Hi all,
Amazing thread...I got inspired with all the Eastern promise of nirvana and bought 2 x the 2SK82's...but...I feel it will not have the power I crave..sooo rather than shelling out big bucks on heatsinks trafo's etc and being left wanting anyone here think I could use these in some sort of buffer/preamp in front of some quality T amp monoblock modules or similar? I only use CD as source at present (direct out from DAC via caps - soon to be sowters in balanced configuration) so could keep it really simple, was thinking maybe stepped attenuator then simple circuit with the SITS into class T somethings, maybe hifimediy mono blocks (still researching this part)
Old 20th January 2013, 12:51 PM   #1596
OlavHaal's Avatar
Cool Power ?????
Hi Garuda77!!
You said " - but...I feel it will not have the power I crave.. -"
And to that I can support some info. Today I have the same DirectOut Dac with Sowther`s - through the B1 passive preamp - then through my homemade monoblock`s SIT(2x8 watt ca) - then through my newly-made Alpair 12P(93 db) in PortedCabinett.
And when I today turn my volumepot up till around 50 % on the B1 it is just perfect - you can hear EVERYTHING - the little touch on the strings on the gitars - the way Rickie Lee Jones is wriggling her voice in The Weight on the album The Devil You Know. When earlier playing my chain on the Alp10.2 without the Sowther it culd be a little low on some album(earlier R.L.Jones and some) - but now with Sowthers and the Alp12P it is really filling the room with sound. especially Voices and acoustic instument is getting the full treatment.
So the SIT is PERFECT on efficient speakers(if you have Sowthers especially)!!
Best
Olav
Old 20th January 2013, 04:40 PM   #1597
juanitox's Avatar
Default DCB1 and SITAMP
do you think it"s possible to drive directly the SIT with the DCB1 output without any capacitor or resistor just making the bias with the OFFSET of the DCB1 ?
( let say 11V+ and -16V negative rail)
Old 20th January 2013, 04:57 PM   #1598
OlavHaal's Avatar
Arrow Questions...questions....
Hi Juanitox!
If you are asking me - I`m sorry to say that I don`t know. Let`s send the question further to the guy`s who are the experts: Michael or who else - Mr Pass?.
My SIT-version is selfbiasing and I have moved my 10microF Obbligato from the output of my B1 and to the input on the SIT.
And I have moved to building Dac`s for a while(even if I have a couple spare 2SK82 waiting for LumiaAria - if that is the chosen part!!!)
The sound is so full-bodied and elegant - as is - with the Alp12P!!
Best
Olav
Old 20th January 2013, 05:03 PM   #1599
juanitox's Avatar
or ZM perhaps if he is in a good day
Old 20th January 2013, 05:15 PM   #1600
OlavHaal's Avatar
Yepp-yepp
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 20 2nd March 2013 08:26 PM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2013 diyAudio
