Old 11th January 2013, 12:47 PM   #1571
Telstar is offline Telstar  Italy
Yes! Elma are my first choice. Used by goldpoint and not hard to find in Europe.
But those i found are with single pcb (per channel) with little spacing, for smd resistors. I'll look further (or get the pre-mounted one)
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 11th January 2013, 01:05 PM   #1572
Yours are stepped attenuators that have always a chain of resistors in the signal path. Mine only one resistor at each step. A couple of years ago I purchased the last two from a British distributor. They seem to be hard to find meanwhile and if you get some, they are quite expensive.
But have a look at these high grade attenuators from Poland: High Quality Audio & Industrial Attenuators and Passive Preamplifiers
Old 11th January 2013, 02:20 PM   #1573
Mine? I have got none yet.
You mean a shunt attenuator, i plan something like that.
They had mixed quality issues, so I prefer to go with Elma.
Old 11th January 2013, 05:30 PM   #1574
What kind of quality issues?
Old 11th January 2013, 10:47 PM   #1575
Search there is a thread in this forum.
Old 12th January 2013, 08:41 AM   #1576
I have read the comments at Khozmo 48 position stepped attenuators.
Sounds good, at least in my comprehension...
Old 12th January 2013, 09:40 AM   #1577
juanitox's Avatar
Originally Posted by Michael Rothacher View Post
Do you mean a 10k volume pot? The effective input capacitance of the 2SK82 under L'Amp operating conditions was a couple thousand pf as I recall.
can i repeat my "newbie" question ? what is the effect of this input capacitance and how to cure it on the Sit ?
French is not a crime.
Old 12th January 2013, 01:02 PM   #1578
www.audiohobby.com
The effective input capacitance and the output impedance of whatever drives it form a low-pass filter with cutoff = 2*Pi*R*C
So, driving the SIT with a 600 Ohm source gives:
6.28 * 600 * 2E-9 = 133 kHz
And, for example, hanging a linear 50k volume pot on the input, set at 50%, gives:
6.28 * (600+12500) * 2E-9 = 6 kHz (which is hi-fi for humpback whales)
Old 12th January 2013, 01:52 PM   #1579
juanitox's Avatar
thanks michael i understand , so the 10K and 47K resistor loading the gate is not in the impedance calcul ? or perhaps for high pass with the coupling capacitor ? i understand but slowly
Old 12th January 2013, 01:58 PM   #1580
From Michael's calculation I get that a 1k pot would be ideal to not have HF rolloff.
My source is very low impedance so I could use a 1k pot, the problem being it unobtainium
Therefore i'll build a stepped attenuator taking advantage of the 10k (which i erroneously called inpout resistance) in it.
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 20 2nd March 2013 08:26 PM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2013 diyAudio
