L'Amp: A simple SIT Amp
Old 10th January 2013, 11:45 PM   #1561
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Originally Posted by Telstar View Post
Happy new year to everyone!
I'm starting to prepare things to build a scaled-down version of the l'Amp with CCS for use with lowZ headphones.
The first question is about the input impedance of the K82. Since I would like to use a 10k pot, i would have to raise the input resistor to 100k - is this ok?
Second, if someone -possibly in EU- has a pair of IXTH6N50D2 that could sell me.
Otherwise I have to order from digikey.
Do you mean a 10k volume pot? The effective input capacitance of the 2SK82 under L'Amp operating conditions was a couple thousand pf as I recall.
Most of my samples have a microamp or so of leakage current.
Visit AudioMaker.Tech
Old 11th January 2013, 06:53 AM   #1562
juanitox is offline juanitox  France
juanitox's Avatar
a private joke... he make the LDR passivepreamp i use . see the Warpspeed thread...
French is not a crime.
Old 11th January 2013, 07:01 AM   #1563
juanitox's Avatar
what is the effect of this ? limited band witch? bias problem stability ?
Old 11th January 2013, 07:18 AM   #1564
generg is online now generg  Germany
generg's Avatar
Originally Posted by Blues View Post
Ahem...
Generg,
Going thru the question and answer related to Nelson's answer above, I think he mistook your 100k for frequency(Hz) instead of the 100kohms that you meant so if you clear this up we might get a better answer.
I think you are right, Blues!
Thanks!
and the First Wtt is......a really First Class PSS Idea
Old 11th January 2013, 10:16 AM   #1565
protos is offline protos  Greece
protos's Avatar
This would be a good option, yes
I just checked the cost of attenuators and I froze I think diy is the only option either way.
I agree Telstar plus perhaps with HP's you do not need so many settings as with speakers in the volume control - perhaps only 6-7.
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´
Morgan Jones, Building Valve Amplifiers.
Old 11th January 2013, 11:11 AM   #1566
Telstar is offline Telstar  Italy
I need at least 24 steps, cutting away the outer zones (i.e. choosing resistors to provide fine control in the normal listening level).
ATM I'm choosing the switch to use, and i'll order next month.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 11th January 2013, 11:53 AM   #1567
protos's Avatar
I think you will spend more time soldering the attenuator than on the rest of the amp.
Good luck and keep us informed. What headamp will you compare it with ?
I have a PPA.
Old 11th January 2013, 12:48 PM   #1568
Hell yes! but i found one already mounted with Holcos... is my time soldering it worth 20£? i think yes.
I have a PPA.
For comparison:
-modded CK2III
-Marsh Headamp (to build right after L'Amp)
Same regulated psu (varies only voltage and transformer size, type is the excellent Nuvotem potted).
The SIT is the bigger of the lot, I think I'll order a 100VA transformer for mine (+35v/0.5A bias).
Old 11th January 2013, 12:52 PM   #1569
I have a PPA.
I'm playing with discrete designs so far, other 2-3 further down on the list (a JLH 69, an italian project called VHF-N and an F5 or aleph redux with laterals).
When I'm done with all the ones I think are worthy, I'll check opamps (not many output ones high current types avail).
Old 11th January 2013, 01:04 PM   #1570
permaneder is offline permaneder  Germany
I soldererd a lot of these good old ELMA audio attenuators.
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 02:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 08:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 15th November 2011 12:41 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 09:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 11:46 AM
