L'Amp: A simple SIT Amp - Page 153 - diyAudio
Old 28th November 2012, 07:38 PM   #1521
juanitox's Avatar
Hello here is the contact:
l-ogonowski@o2.pl
Let us know how they sound...)
i have send it 2 mails , no response yet
French is not a crime.
Old 28th November 2012, 07:48 PM   #1522
Strange, I got qucik response...
You can maybe try here: Ogonowski.eu - profesjonalne transformatry do wzmacniaczy lampowych
Old 30th November 2012, 01:55 PM   #1523
I am just wondering if someone has the original 2sk82 transistor datasheets???
Old 3rd December 2012, 05:18 PM   #1524
I guess not...
By the way has someone already ordered the plate chokes from Poland?
Old 3rd December 2012, 05:51 PM   #1525
generg is offline generg  Germany
generg's Avatar
the only thing i found you may all have.....
and the First Wtt is......a really First Class PSS Idea
Old 3rd December 2012, 05:57 PM   #1526
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
2SK82 SONY
J (V) -240 GDO 10A 95W
http://www.minor-audio.com/data/2SK/2SK0011-0100.htm
I build, therefore I am.
Old 3rd December 2012, 06:05 PM   #1527
Thank you guys...I have this papers allreday.
I searched in some old sony V-fet power amplifier manuals but didnt find anything we dont know.
It looks like sony has made a lot of them, since the codes differ and so does the pinch voltage...
Old 19th December 2012, 12:44 AM   #1528
Here's a pic of me checking the power supplies on my SIT. More to follow soon!
Dan
Old 19th December 2012, 07:44 AM   #1529
protos is offline protos  Greece
protos's Avatar
Very neat!
Although if this a photo of you (checking your power supply), you are going to have a hard time with the opposite sex
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´
Morgan Jones, Building Valve Amplifiers.
Old 19th December 2012, 08:50 AM   #1530
protos's Avatar
Just to let you know that after completing the second mu-SIT monoblock and setting them up I proceeded to audition more carefully vs the two single ended valve amps (300b and 6c33) I also have made. Pre was an Aikido (John Broskie) with 6h30 and 6cg7.
Some preliminary points:
1. The 8 SITS I bought have very variable characteristics as I already mentioned in a previous post. I rechecked with more careful installation on the heatsink this time. Basically I set up my PS to 2amps constant current mode and I varied the bias between -1 and -5 volts , noting changes in Vds. Essentially this gives you the Gain of each device. I was surprised to see a variation between about x2 to about x6. That is more than 200% variation in gain characteristics!! Fortunately there were two sets that had similar characteristics which I used but still the two amps have about 1db or so difference in gain which is a bit academic and I did not really notice in practice.
However be warned that if you just order two 2sk82 you might get two VERY different vfets.
2. Even with the two matched vfets when I adjusted for lowest distortion I ended up with one sitting at about -4 V bias and 3 A and the other at -5.8 V and 2.4 A.
Anyway with two big film in oil 100uf on the output (this SIT feeds full range speakers only down to 100hz the rest below 100hz is with a powered sub) the sound is really good on the same playing field as a good SET and very probably better. In fact I do prefer them over my SET amps now that they are dialled in and without electrolytics on the output. More precision without losing any of the SET musicality. I would not recommend them with non SET friendly speakers because I noticed a lot of higher order distortion on the distortion analyzer when pushed nearer their output limits. So if you have speakers of 96db sensitivity or more this amp is really great and you do not have to keep replacing those super expensive valves every couple of years (although I believe the 6c33 is very cheap compared to some 300Bs)
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2017 diyAudio
