L'Amp: A simple SIT Amp
Old 29th July 2012, 07:05 PM   #1371
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
L'Amp: A simple SIT Amp Send a message via Yahoo to vdi_nenna
It's difficult for me to recommend a $14 resistor when a $1 resistor might sound just fine.
Like you said, it's low parts count. It's in the signal path. I might argue that is a important resistor, then again, my RCA only cost $3 a pair. By comparasion, I should have spent $50 each on WBTs. Too bad Eichmann doesn't make a low mass RCA jack.
Anyway, your mileage may vary. Experimenting is fun. Listening is fun too.
I build, therefore I am.
Old 29th July 2012, 07:37 PM   #1372
juanitox is offline juanitox  France
juanitox's Avatar
you are right , i'am able to recommend a resistor to my taste , but i have a 10$ speaker cable on my system to listen it
French is not a crime.
Old 29th July 2012, 07:52 PM   #1373
vdi_nenna's Avatar
I'm using 30 gauge at $5 for 40 feet. That's no misprint.
Old 29th July 2012, 07:58 PM   #1374
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Thumbs up Yeah to both....
Yes Gentlemen...
The fun is in the building - not the price! My friends Hi-Fi system (MLogan,ElectroComp,Shanling etc) cost more than 10 times the cost of mine. It may sound a little better, but he does not have the same amount of joy in searching and trying to find that spitz-feeling in the right component. And my system is more dynamic and touchable than his.
And my cheap Sony SCD-XE800(260 dollar here in Norway) is able to play SACD and DSD-DSF disc(burned on DVD). Not many discplayer at that price is able to do that. And the sound is more than acceptable for me!!
But what LDR-pot did you use Juanitox?
Best
Olav
Old 29th July 2012, 08:06 PM   #1375
juanitox's Avatar
i have a " lighter note" ldr Kit from buildanamp but the simple optivol will do the same. in fact i prefer mine with a fixed caddock series resistor and a LDR variable shunt as the optivol than as full LDR volume pot .. please don't ask me why
i have tried the Sit Amp with just a passive LDR pot but it sound dull , much better with the B1
Old 30th July 2012, 01:15 AM   #1376
vdi_nenna's Avatar
Olav, what software do you use for recording DSD-DSF files?
Old 30th July 2012, 06:16 AM   #1377
OlavHaal's Avatar
Cool sorry - off for a while...
Hi Vdi_Nenna!
Was occupied with other things late yesterday, but now I`m back in line: to record a DVD with DSD-DSF files you don`t need any special software. An ordinary computer with CD-ROM and a standard WindowsLive or other DVD-burner software(that is included in most PC`s).
But you have to download the files - unpack them - to a folder of your choice - then you make a mother Folder - name it DSD_DISC - and inside that folder you saves your music files that has an ending with DSF.dsf(which is generated automaically at unpacking w the files from BlueCoast). And then you can play them on the Sony SCD-XE800 or Sony Playstation 3(and maybe some expensive other players)
But you can also download them as DSD-DFF and store them on the computer and later play them from the computer with the AudioGate player from KORG. It is partly free(but you has to have a Twitter-acount to do that).
And you get the problem with a good DSD capable DA-converter to get the files to the B1. (Meitner MA2 costs 11000 dollar, but there is cheaper than that) And you must have a computer connected to the DA-converter!
I personally DON`T want to be tied up to the computerized music-handling. I play my stored files via Squeez Touch, but don`t think that is a perfect solution(server,software).
So for me the Sony was a cheap - fun - easy - solution.
If you want I can give you a link to where the info is: how to burn DSD_DISC on Sony SCD player.
Just ask
Best!!
Olav
Old 30th July 2012, 10:03 AM   #1378
nicoch58 is offline nicoch58  Europe
me too , nice to know that I'm not the only ones....
probabily you don't like too much second harmonic
btw I have no tested the full ldr , I use shinkoh ,try....
Old 30th July 2012, 11:22 AM   #1379
OlavHaal's Avatar
Wink Hi Nicoh
Hi and thanks for supporting info about the LDR-potmeter! And I was thinking about trying the Shinkoh - but it ain`t available in 220ohm. As Juanitox and other(I can give good link) has suggested - it is worth to try with 220 ohm for R102,R202, R104,R204. So I wanted to try that with the Amstrad-resistors.
Maybe a Shinkoh or Charcroft later.
But nice to have such eagerly diy-fellowers searching for the fine sound in Pass-related stuff.
Best from olav
Here is a quote from a mail I got from BlueCoast`s - Cookie Marenco just 5 minutes ago:
Closing note
We've set up our Sony AR1 speakers with Pass Labs amp and it sounds spectacular in the studio. We've created an alternate listening area for mastering--a dream come true. That brings the total to 7 different sets of speakers we check our mixes through and we love them all!
Old 2nd August 2012, 06:42 AM   #1380
kasey197 is offline kasey197
The Dastardly Dad of Three
hullo all... not sure if this question has been asked before, but .... in the SIT nemesis article, NP mentions: "Also I have reason to believe that we will see some new SIT parts from a couple of sources in the coming year – parts that you should be able to actually buy."
Anyone any ideas what/where/when apart from the vintage VFETs ? These SIT thingies look just the bee's knees for amazing low/no fb amps ....
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 02:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 08:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 15th November 2011 12:41 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 09:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 11:46 AM
