L'Amp: A simple SIT Amp
Old 26th July 2012, 06:30 PM   #1361
juanitox is online now juanitox  France
juanitox's Avatar
193V works fine at 2amp
French is not a crime.
Old 28th July 2012, 10:37 PM   #1362
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
L'Amp: A simple SIT Amp Send a message via Yahoo to vdi_nenna
Finished the SIT CCS. It biased up and locking in at 1.55v across 1 ohm resistor.
Played an MP3 through it to hear something and I can tell there is something special about it already. Vocals are pretty freaky! :-)
Thanks to Mike and everyone!! :-)
I build, therefore I am.
Old 28th July 2012, 11:13 PM   #1363
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Congratulations!
Now get ready to spin some wax.
Visit AudioMaker.Tech
Old 29th July 2012, 12:18 AM   #1364
vdi_nenna's Avatar
No joke. Threw on some Berlioz. Symphony Fantastique.
Crazy! Then I realized the phase was reversed on the outputs.
Going to have to listen all over again!
Old 29th July 2012, 02:09 AM   #1365
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Don't laugh. With SITs it tends to make a difference, depending on the
recording.
Old 29th July 2012, 02:35 AM   #1366
vdi_nenna's Avatar
recording.
It made a big difference, yet it wasn't completely annoying. Took a few tracks to figure it out.
This Cool Aid tastes good!!, Its going to be hard going back to anything else.
Hope SITs become more available soon, like you said.
Old 29th July 2012, 07:01 AM   #1367
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Smile Try some higeher resol...
Hi Vdi_Nenna!
You should have a go at some good Wav or DSD recording - yesterday I downloaded some from BlueCoast in 2,8 MHz resolution - burned them to a DVD - and played them through my new Sony SCD-XE800.
And through my B1 - SIT resistorbuildt - and it is like the whole acoustic band is inside my living room.
I have ordered some Amtrans resistors in the signal path on the B1 and the 47 ohm on the SIT. Just to hear if resistors make a difference.
Best
Olav
Old 29th July 2012, 08:18 AM   #1368
juanitox's Avatar
hi olav , yes it makes differences i have changed these from carbon film ( KIWAME) to Charcroft Z foil , and Cadock MKP132 and first i was somehow disappointed as it sounds less warm but at last i prefer this more transparent sounds but the best trick i have done is to replace the gate resistor load of the SIt with an amorphous Silk grid choke. as this swapping the 10uf input Cap with a 0,22uf Vcap teflon without loosing bass
Old 29th July 2012, 11:02 AM   #1369
vdi_nenna's Avatar
Best
Olav
Thanks for the site tip. I'll check it out.
Using a naked Vishay 47 ohm resistor at the gate. There's a Mundorf cap at the output, but will switch out for a ClarityCap to see the difference.
Old 29th July 2012, 05:40 PM   #1370
OlavHaal's Avatar
Wink So many suggestions
Hi Juanitox and Vdi_Nenna!
Yes - I also wondered about the naked Charcroft as gate resistor and in signalpath resistors in B1. But I will first change my Wima 1uf w Obliggato and old Dale metalfilm with Amtrans to see if it is room for further impowement.
Then later I will change to Charcroft if you think it still is a good idea? Good to have some exciting change of sound later this year.
There are so few resistors in our amplifiers anyway - so it woun`t be any big amount of money with some change at times(once the amplifiers mainbuild is up and running) Just fun to change!!
And you Juanitox changed your potmeter to a LDR - I need one myself. I have found the OptiVol which looks promising - and with a zenerdiode(15v) it can be fed from the supply that feed B1.
Best to all
Olav
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
