Old 25th July 2012, 04:14 PM   #1331
juma is offline juma  Serbia
juma's Avatar
Hi vdi_nenna,
I think that the main thing that ZM wanted to warn you about is that heat tends to go upwards and if you mount your SITs so high up the heatsink the heat won't spread evenly, and the lower parts of the heatsink will be much cooler i.e. unused and your SITs will needlessly be exposed to much higher temperature. Lowering the position of L-profiles to about 2-3 inches above the bottom would put your SITs in much more comfortable temperature zone.
Old 25th July 2012, 04:26 PM   #1332
flg is offline flg  United States
flg's Avatar
Originally Posted by vdi_nenna View Post
Generg, love your work and your persistance. Keep it up. I have always been interested in your Mu/J2 work.
Case appearance doen't matter. A friend in my audio group saw my system and didn't think much of it on appearance. Once he heard it, he said and I quote, "You can't let the others in the group hear this, you'll have a revolution on your hands." Best compliment I ever received!! Owe it all to you guys and I never take credit for any of it. You are the geniuses!
generg, What he said! Choos (sp?)
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 25th July 2012, 04:34 PM   #1333
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Thanks Juma. I know, but I can't move the L bracket on one of the heat sinks. See pic attached.
On the right heat sink back corner is a set of stacked plates that are not physically flush with the face of the heat sink. It's imperfect. The plates are more or less cometic.
If the L bracket is moved down, the same problem exists because of the plates, except it's half the heat sink in the lateral direction that's not being utilized.
This heat sink was meant for an F5, where there would be more space to mount TO-247 directly on he heat sinks, without the aid of the L bracket.
If I mount the L bracket vertically, that's not good either. Best thing to do is flip the heat sinks and have the bracket be lower, but does that make sense?
Heat distribution is still uneven. It's still not in the middle of the heat sink.
I build, therefore I am.
Old 25th July 2012, 04:43 PM   #1334
juma's Avatar
... I can't move the L bracket on one of the heat sinks. See pic attached....
Yes, this way or that way there's always something that needs extra care or attention. Never you mind, it won't kill the SITs for sure. It's just that nagging feeling that it could have been made a bit better...
Old 25th July 2012, 05:22 PM   #1335
vdi_nenna's Avatar
It's just that nagging feeling...
I know, and thanks to all you for the suggestions and concern.
Why I got stuck with a heat sink like that, I have no idea. Well, maybe because it's surplus.
Thanks again. I'll speak up again after I give it a listen. Hopefully by this weekend.
Old 25th July 2012, 06:26 PM   #1336
juanitox's Avatar
cool work! and don't worry so much about the heatsink i have small ones and can lay my hand on it few minutes without "barbecue" effect with 40W on the 2SK82
just to say i found that the SIT needs a good preamp in front of it , i have a passive LDR and it never sound good with it. so i have built a little DC coupled B1 buffer and the combo sounds far better
French is not a crime.
Old 25th July 2012, 06:35 PM   #1337
vdi_nenna's Avatar
Thanks juanitox.
This makes me wonder if my smaller heat sinks, already drilled for TO-03, would have worked. Will take picture and post it. I have 4 of them. They are maybe 5x5x3 inches in size, but have fins in all directions like Mike's photo in L'amp CCS article. Although on visual inspection, not as heavy an extrusion as Mike's heat sink.
Do you have a photo of your amp here?
Found a picture on the web. the one in the back. Not exact, but close. Mine is more like a cube.
Damn.
Old 25th July 2012, 06:50 PM   #1338
juanitox's Avatar
this is mine..
Old 25th July 2012, 07:10 PM   #1339
vdi_nenna's Avatar
That's it?!?!?! That's all? Tell me they go into the case, please!
Had no idea it could be that small!! The extra heat sink I have are at least that big, maybe bigger.
Also have 8 heat sinks that are bigger than that one, if I take apart my Zen v1. I used the transfo from the Zen 1. It ran at 2 amps.
did I mention I have 2 extra 2sk82s not in use?
Nice wood case.
Old 25th July 2012, 07:48 PM   #1340
KASUMI is offline KASUMI  United Kingdom
Got the resistors juanitox...thanks
What did you use as an alternative ?
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 20 2nd March 2013 08:26 PM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2013 diyAudio
