L'Amp: A simple SIT Amp
Old 27th December 2011, 07:34 PM   #121
juanitox is offline juanitox  France
juanitox's Avatar
I'm sorry I don't understand your question
it s good to laugh ............sometimes:
French is not a crime.
Old 28th December 2011, 04:35 AM   #122
Nikon1975 is offline Nikon1975  Austria
I may have found an home for a 45VAC 13A toroid I saved from the trash !!!
D.
Old 30th December 2011, 10:21 AM   #123
stefanobilliani is offline stefanobilliani  Italy
Just received as a New Year nice " gift " .
Old 30th December 2011, 12:26 PM   #124
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Shiny.
Happy New Year!
Visit AudioMaker.Tech
Old 30th December 2011, 12:27 PM   #125
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Default Silly Question....
Hi Michael!
Some misconception for my part - I have found 120volt - 150Watt bulb(both internett & E-bay), but I started wondering: do we need 2pc 120Volt/300 watt i paralell per channel: That means we have 600Watt pr channel = 1200Watt pr. LÀmp? I have mine Alpair 10.2 in SelfMadeFonken which is Nominal= 6,1 ohm. So i have to keep down to around 8-10 ohm and 600Watt(bulbs + eventually resistors in combination) on each channel. Or can I keep it to around 10 ohm AND 300watt???
When I read the DeLite thread I think I saw 2 bulbs and each was 150 watt.
Hope you can give a clue to a somewhat novice in North Europe(Norway) - well been into electronic most of my life....
PS.
Mine 2SK82 KD33 arrived in the post Yesterday - Hurrah!!
So before I get the rest of the gear, heat sinks, trafoo and such...will be a project in the course of the spring!
Many thanks and blessed be to ye all in the New Year.
Olav
Old 30th December 2011, 12:50 PM   #126
AudioMaker.Tech
Hello Olav,
You're looking for around 10-13 Ohms. One 300W@120V bulb measures approx. 22 Ohms, so two in parallel are 11 Ohms. So, you need two 300W bulbs per channel.
You can use any combination of bulbs that gets you to 10-13 Ohms, or use a resistor.
BTW, a 6 Ohm, 87 dB speaker is really not going to be a good match for an amp like this.
8-16 Ohms, High Efficiency.
Old 31st December 2011, 12:27 AM   #127
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
So, I have a reading comprehension type question. Great article by the way.
So, your bulbs drop a lot of voltage, along the lines of 25-40V. If you had a CCS which required a lot less voltage to operate then you could get away with a lot less B+ voltage. If I understand your table correctly, you only need 13.6V to 15.3V plus whatever it takes for the CCS to operate?
Now where did I put that old AudioXpress article...
Old 31st December 2011, 06:27 AM   #128
juanitox's Avatar
how to build or by a CCS with 3amp output ?
Old 31st December 2011, 01:45 PM   #129
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
You may have a look into the Zen variations #9 where you can find a 2amp example.
http://www.firstwatt.com/pdf/art_zv9.pdf
Franz
Old 31st December 2011, 02:09 PM   #130
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Franz
And a nice slow start reg.
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
