L'Amp: A simple SIT Amp
Old 27th December 2011, 05:40 PM   #111
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
May I ask why you are so determined to have a bypass capacitor? Is it for the extra gain?
Old 27th December 2011, 05:48 PM   #112
juanitox is offline juanitox  France
juanitox's Avatar
the extra gain yes and not to have feedbach or a 10uf series Cap at the input signal...
French is not a crime.
Old 27th December 2011, 06:36 PM   #113
AudioMaker.Tech
I didn't listen to the amp with the bypass capacitor. In my case, the added distortion wasn't worth 3-4 dB of gain, so I didn't pursue it further.
You leave me a little perplexed. The source bypass cap does not make direct coupling the input any more or less possible. The input cap is there in Figure 11 in case your SIT has enough gate leakage current to drop some voltage across the input. If you measure the input, and it is at 0V, then perhaps you can go without.
May I suggest building the circuit as intended, getting it working, and then you can experiment and make sparks as much as you wish.
If you really want more gain and no degeneration, the circuit with the negative bias supply is the way to go.
Old 27th December 2011, 06:45 PM   #114
juanitox's Avatar
i mean i choose fig 11 instead of fig 10 because i can swap the input Cap and the negative bias circuit.. but if it must sound bad as it , i will change to fig10
with this
is there a problem just to have 10ohm resistor for the drain ? or is it must be 11/12ohm
Old 27th December 2011, 06:48 PM   #115
AudioMaker.Tech
10 Ohms will change the operating point, you can certainly try it though.
Are your speakers 8 Ohms?
Old 27th December 2011, 06:56 PM   #116
juanitox's Avatar
yes , avant-garde nano are 8ohm nominal.
Old 27th December 2011, 07:01 PM   #117
AudioMaker.Tech
Wow, those should sound terrific. Try the 10 Ohm. It's easy enough to add some resistance if needed.
Old 27th December 2011, 07:13 PM   #118
juanitox's Avatar
thanks michael , sorry to be the dumb and dumber of your post
do you think i still can use the 25k gate leak that i have already sold and mount on the 2SK82 with the LM337 schematic?
Old 27th December 2011, 07:21 PM   #119
AudioMaker.Tech
No worries. We're all here to learn and have a little fun hopefully.
I'm sorry I don't understand your question.
Old 27th December 2011, 07:26 PM   #120
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2017 diyAudio
