Old 14th May 2012, 05:50 PM   #1091
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
F1 is important in PSUD
make your sim , attach it zipped here , and you'll get some help
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 14th May 2012, 06:07 PM   #1092
www.audiohobby.com
Yes, more info needed. Ringing in what? The simulated power supply?
You could just replace the CRC resistor with a 12-14 ga. 2-4mH air core coil if you want a CLC.
Old 14th May 2012, 06:33 PM   #1093
juanitox's Avatar
hi Kasumi , could you try my config in PSUD ( i don't know how to use correctly PSUD ) with 18V AC 22000uf ( 0,01 esr) 10mh ( 0,47 ohm) 37000uf (0,01 esr) .. and tell me if you see any ringing? thanks !
French is not a crime.
Old 14th May 2012, 06:47 PM   #1094
KASUMI is offline KASUMI  United Kingdom
Originally Posted by juanitox View Post
hi Kasumi , could you try my config in PSUD ( i don't have windows PC ) with my CLC 18V AC 22000uf ( 0,01 esr) 10mh ( 0,47 ohm) 37000uf (0,01 esr) .. and tell me if you see any ringing? thanks !
First time I used PSU D was yesterday ,so I doubt I know what I'm looking at or doing.
There is a very knowledgeable bloke on another forum I use that inferred that there was ringing in the sim I had using a 20mH inductor in a CLC config.
I started with that as that was what you said you used in a past post.
I'll just go with what Mike recommended 2-4mH and leave these sims to the pros
Old 14th May 2012, 07:20 PM   #1095
www.audiohobby.com
Those values worked nicely for me. I haven't tried any big iron myself, but I'm sure its good.
It's hard to say what your friend might be referring to, so I can't help there without seeing the simulation results.
You could observe the real ripple waveform with your scope if you have one.
Old 14th May 2012, 07:33 PM   #1096
i_should_coco's Avatar
Hey Rob, just to clarify, I think you might have misunderstood - I didn't say there was ringing in your sim (I didn't actually sim it yet), I just suggested using PSUD to simulate your cct. and one of the things to look out for is ringing when you add a current step (you can see the oscillation in the waveform. I was in a hurry ad missed the details in your PM. Knowing the DC resistance of your power transformer and proposed choke would be good, too as they will affect it.
Old 14th May 2012, 07:40 PM   #1097
Here's a sim using similar values to the ones you sent: 37000uF - 20mH - 37000uF, 2.5A load. (I substituted a Hammond 159ZE (28mH, 0.43 Ohms) choke as that's a real part.
Look like you get about 2V ripple! That seems quite high...
Old 14th May 2012, 07:44 PM   #1098
whoops,yep I'd thought you'd done a sim ISC and had seen some ringing and thought it may have been overlooked
Old 14th May 2012, 07:48 PM   #1099
Zen Mod's Avatar
2R for 37mF !!
yikes!
Old 14th May 2012, 08:11 PM   #1100
Good point, I'm more used to tubular stuff. What's a sensible value? 0.1R?
ok, 0.1R give more sensible results. No ringing when stepped, but looks a bit over-damped to me - I'd aim for a slightly faster rise.
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 20 2nd March 2013 08:26 PM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2013 diyAudio
