#101 |
Hi all!
Just to have a note before the holiday: my old schoolteaching tells me - if you have a halogen bulb with 24 volt and 100 watt = 24x24=576 divided on 100 = 5,76 ohm!! Then you have 3 in seriell= 17,28 with 300 watt. If you then keep 3 more in paralell to those first 3 you end up with 600 watt AND 8,64 ohm. That is pretty close - and if you give 1 resistor in seriell with those bulbs - you get even closer. I have found som small bulbs(halogen 100 watt, 24 volt) here in Norway. My SK82(KD33) was ordered 1 week ago. so the build will start in feb/mars! Happy New Year Greetings to all Olav |
#102 |
Olav
I was talking about 300W/120V bulbs, not 24V. O.K. maybe a way to go. Thanks for all answers up to now. Franz |
#103 |
Yeah - I know that it would be a closer fit with 300watt and 120 volt, but it is somewhat difficult to get hold on 120 volts bulbs here in Norway - and with 230 volt and low wattage bulbs it is even vorse(like 230 watt and 20 or 10 watt)!
That is why I am thinking to try my amp with those 24/100 watt bulbs? Maybe? Best to all. Olav
#104 |
French is not a crime. |
#105 |
not politcally affiliated
#106 |
oops 75h of life...
#107 | |
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
#108 |
Hi again!
Here is my finding: From the ELFA catalog: 4000 HOURS!!! : https://www.elfaelektronikk.no/elfa3...4-48&toc=19002 A search gave me this result - maybe it can be that i nyour country too?? Good luck - and the best to you. Olav
#109 |
www.audiohobby.com
Out of sheer morbid curiosity, I tested a large source resistor bypass cap (47,000 uF) and the results were not especially good. 1W THD climbs from .07% to around .5%.
My Website, Projects, Sale Items |
#110 |
0.5% not so bad for me ..
and the sound?? i must be sure that i will kill my SET amp
| L’Amp: A Simple SIT Amp: Part 1 | Michael Rothacher | diyAudio.com Articles | 20 | 2nd March 2013 08:26 PM |
| SIT Amp Article Out Now | Variac | Site Announcements | 0 | 2nd December 2011 07:55 AM |
| Srajan has the 1st SIT amp for Une dégustation | vizion | Pass Labs | 131 | 14th November 2011 11:41 PM |
| SIT-Preamp | VladimirK | Solid State | 36 | 27th August 2011 08:36 PM |
| New SIT - old problem | StevenOH | Parts | 2 | 13th June 2008 10:46 AM |
