#1061 |
Hi again.
No - and yes - I have two sources: Squeezbox Touch that feeds through a DacMagic. And a HD980 CD-player that also is connected to the DacMagic. So I run both through the B1. And I can run the pre-out from my HK980 which also is relative good. But I think the B1 is so good - so you really relieved me now Michael. Just a couple of resistors and soon ready to go.....rock and roll!!! ![]() Best to all Olav |
#1062 |
Sounds like a job for a BOZ or JBOZ... My battery powered J310 based JBOZ works quite well...
Roscoe |
#1063 |
Hi,how do you guys get rid of the switch on thump,though I get no thump just the drivers cone popping out alarmingly
![]() only just noticed today |
#1064 |
One of the simplest ways to get rid of turn on thump is to put an inductor in the power supply. It resists a change in current, and so, turns on the power supply slowly. Result = no turn on thump. As a bonus, you get a quieter supply compared to a standard CRC. Start with 2mh, 16ga. Read the Zen articles.
Another way is to disconnect the speaker before turn on. And then are more complicated ways. |
#1065 |
and another way is to put delayed shortie in paralel with spk
there is cap , so no harm
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#1066 |
#1067 |
do you have bleeder resistor , in parallel with speaker ?
#1068 |
#1069 |
www.audiohobby.com
A "bleeder" resistor across the speaker terminals will discharge the big output capacitor, which is a good idea. You could try a 3W 100 Ohm, for instance. A bigger value will discharge more slowly / smaller value more quickly.
As far as turn-on thump goes, my low-tech approach is to install a shorting banana plug across the speaker terminals, temporarily shorting the output to ground for a few seconds during power up, then I remove it. I may have mentioned this in the text. Also, see the Zen Lite article for an automated version of the same idea. Is that fancy square thing a capacitor?
My Website, Projects, Sale Items Last edited by Michael Rothacher; 11th May 2012 at 12:45 AM. |
#1070 |
| L’Amp: A Simple SIT Amp: Part 1 | Michael Rothacher | diyAudio.com Articles | 20 | 2nd March 2013 08:26 PM |
| SIT Amp Article Out Now | Variac | Site Announcements | 0 | 2nd December 2011 07:55 AM |
| Srajan has the 1st SIT amp for Une dégustation | vizion | Pass Labs | 131 | 14th November 2011 11:41 PM |
| SIT-Preamp | VladimirK | Solid State | 36 | 27th August 2011 08:36 PM |
| New SIT - old problem | StevenOH | Parts | 2 | 13th June 2008 10:46 AM |
