#1051 |
I picked up 4 different input caps to test: ClarityCaps, Mundorf, Zen Audio, and Dayton Audio.
For the input resistors naked Vishays...I figure this circuit is worth it.
I build, therefore I am. Last edited by vdi_nenna; 9th May 2012 at 01:18 AM. |
#1052 |
for the 10uf the clarity cap ESA (250V) is cheap and you can use it on the output too. the quality of the 10000uf is not critical as you bypass them with a 10uf .
also carbon comp for the gate stopper, kiwame 2w is good and small and you can solder it directly on the 2SK82. don't forget the PS if the CRC is good for the Job , i have found in my system that a CLC ( with the same value for the Caps) sounds faster and even more silent with my 102db speaker.. good building at all
French is not a crime. |
#1054 | |
Why are you bypassing the 10k with a 10uF ? I'm learning ![]() What size inductor were you using in the CLC ? Cheers Rob |
#1055 |
hi Kasumi, i'm learning too .. the 10uf bypass on the output cap is to get more open highs than with the electrolyte alone.
for the CLC power supply i use a 10mh hammond choke but Nelson Pass usually use 2mh ones 20$ for a good quality 10uf film Cap is correct when you compare with mundof S/O , VCAP , etc.. and i don't talk of the crazy duelund brand
#1056 |
Hi Michael or the one knowing more than me...
Wondered if I should order 2 pcs of 100 kohm to use instead of the 47 kohm on the gate/earth input? I see NP`s SIT 1 has switchable input 10/100 kohm - to use with passive preamps. My B1-passive may not be able to fully utilize the bandwith of the LÀmp? Anyone.... ![]() Still waiting for my few 1 ohms film-resistors(have some 10 ohms ohmite - but will be too many to paralell) Regards Olav |
#1057 |
SIT 1 have implemented buffer
switch is for pre-buffer/post-buffer permutations in front of you are numerous
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#1058 | |
I guess if you have it $$$$ spend it!
I build, therefore I am. |
#1059 |
www.audiohobby.com
B1 certainly won't have any trouble with 47k. However, it is important to remember that the B1 has no gain and that L'Amp has very little gain. So, if your source is an iPod or something with very little output, you may be disappointed. On the other hand if you have really efficeint speakers it may not be an issue. Ideally, an active preamp with low output impedance, capable of 5-6V out (or more) would be nice here.
My Website, Projects, Sale Items |
#1060 | |
![]() I think Nelson had reasons to skip the 47k from the prototype of SIT-2 the driving of the SITs capacities is better with 1ok, Nelson did the same with the F2J, first the input resistor was 47k too, a compromise between usability for many pres and bandwidth, now you can see that he implemented even 8k2 in the F2J. and as Zen Mod said, the 100k you can switch now in the SIT-1 are done with a B1 like (?) buffer..... so do not buy 2x 100k.... look at your pre output impedance...your B1 can drive the 47k for sure and the 10k also I suppose....but as Mike said yo have not much gain!
and the First W tt is......a really First Class P SS Idea !
| L’Amp: A Simple SIT Amp: Part 1 | Michael Rothacher | diyAudio.com Articles | 20 | 2nd March 2013 08:26 PM |
| SIT Amp Article Out Now | Variac | Site Announcements | 0 | 2nd December 2011 07:55 AM |
| Srajan has the 1st SIT amp for Une dégustation | vizion | Pass Labs | 131 | 14th November 2011 11:41 PM |
| SIT-Preamp | VladimirK | Solid State | 36 | 27th August 2011 08:36 PM |
| New SIT - old problem | StevenOH | Parts | 2 | 13th June 2008 10:46 AM |
