#1001 |
Hi Michael!
Do you care to say if this is appropiate. Nearly finished with my build - but have to travel to Scotland for a quick job(communication on Saipem7000). But I am waiting for a couple 1 ohm res - soon to come. Patient-patient. But if my HeatSink for the SIT(found on E-bay) fail - I have spotted one that should fit in box and maybe in spec. On the Elfa-Distrelec- it is specd: Termisk resistans = 0.5 °C/W. Included is a picture of the HeatSink. I have received a couple spare SK82 - so I`m safe if the first blow. And I didn`t know where to get the proper sink earlier. So Michael - if you could help if my first SK82 goes up in smoke. Best to all - and thanks for all support this far in my build. Olav |
#1002 |
French is not a crime. |
#1003 | |
486K - WAKEFIELD SOLUTIONS - Heat Sink | Newark/element14 Canada |
#1004 |
Hi Juanitox and thanks for positve remarks!
Yes - I think I will run them(mono-amps)with auto-bias always- AND soon order 2 - 100000 mF to mount across the source-resistor together w 10 mf polyprops. So - the danger is bigger if you run without sourceresistor - lucky me who went for the autobias. Today I tried the two 400watt Antek and they delivered accurately 35 Volt AC - which should give approximately 50 Volt DC. Really looking forward to that moment - estimated time till my build is finished is 3-4 hours ++! ![]() Best Olav |
#1005 | |
My first ever Class A amp.
miklos |
#1006 |
www.audiohobby.com
@Olav
.5C/W is good. The heatsink pictured looks reasonable by calibrated eyeball. @dantwomey The 486 is what I used in the original. It's plenty. @All The SITs are pretty robust current-wise, but running them too hot isn't a good idea long-term. In fact, the cooler the better, IMO. Remember, we're already pushing it on the Max Pd. I never hesitate to oversize my heat sinks a bit when possible. Also, do a really good job with the device mounting, clean the surfaces, and use generous amounts of goop. The heat will also affect the gate leakage and perhaps upset your bias. Thermal stuff is often ignored by us DIYers; the more amps you build, the more you'll pay attention to those matters.
My Website, Projects, Sale Items Last edited by Michael Rothacher; 26th April 2012 at 07:27 PM. |
#1007 | |
At any case Good Work Sony!
and the First W tt is......a really First Class P SS Idea !
#1008 |
diyAudio Editor
I just got these on e-bay. My Hope Chest is filling!
175mm x125mm x 125mm |
#1010 |
www.audiohobby.com
I have a pair of brackets made up that will fit those perfectly.
![]() I used Arctic Silver between the bracket and heat sink and bolted it tight with 4X M5 hardware.
My Website, Projects, Sale Items Last edited by Michael Rothacher; 26th April 2012 at 10:44 PM. |
| L’Amp: A Simple SIT Amp: Part 1 | Michael Rothacher | diyAudio.com Articles | 20 | 2nd March 2013 08:26 PM |
| SIT Amp Article Out Now | Variac | Site Announcements | 0 | 2nd December 2011 07:55 AM |
| Srajan has the 1st SIT amp for Une dégustation | vizion | Pass Labs | 131 | 14th November 2011 11:41 PM |
| SIT-Preamp | VladimirK | Solid State | 36 | 27th August 2011 08:36 PM |
| New SIT - old problem | StevenOH | Parts | 2 | 13th June 2008 10:46 AM |
