Old 14th March 2012, 10:09 PM   #131
JimM is offline JimM  United States
Ok let's see if we can agree on some things or if I'm all wet. In simulation with a +/- 32 volt supply in simulation one side of the front end will swing 24 volts peak or for a total swing of 48 volts peak to peak. As I understand the balanced circuit it acts the same as a bridged amp so V1(side 1 ) - V2(side 2) equal to 2 times the voltage swing of one side.
Therefore the output at the speaker would be 48 volts peak or 2 times that for 96 volts peak to peak at the speaker. I understand this does not include any loses in the output stage. If this is not correct please let me know where I am going wrong.
Old 14th March 2012, 11:11 PM   #132
flg is offline flg  United States
flg's Avatar
You were going along just fine until the "Therefore the output at the speaker would be 48 volts peak or 2 times that for 96 volts peak to peak at the speaker. I understand this does not include any loses in the output stage."
In the previous sentence you said "one side of the front end will swing 24 volts peak or for a total swing of 48 volts peak to peak" Good enough. While this is happening, the other side is doing the opposite. -24V peak
At a point during the positive peak, you have +24V on one side and -24V on the other. Some 180 degrees later, you might have that same side doing a - peak, while the other side is doing a + peak. Measureing across those 2 outputs will measure 48Vp-p. Thats all your gonna get
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 14th March 2012, 11:28 PM   #133
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
what's Upp of Aleph X , considering PSU voltage ..... for , say , light or no load conditions ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 14th March 2012, 11:47 PM   #134
rsdio is offline rsdio  United States
I think you're right. An unbalanced amplifier would ground one terminal of the speaker, and vary the other between +24 V and -24 V, for a total of 48 Vpp. A balanced amplifier does not ground either terminal of the speaker, so when one terminal is at +24 V the other is below ground at -24 V, thus, the speaker sees a potential that ranges between +48 V and -48 V, for a total of 96 Vpp.
Apart from the fact that you originally said 45 Vpp and now you're saying 48 Vpp, that would nevertheless be upwards of 30 Vrms measured across the speaker terminals, not across a single output pin versus ground.
EDIT: In other words, the maximum voltage that a speaker sees from an unbalanced amplifier (half the BA-3b) is +24 V, the minimum is -24 V, and the peak-to-peak is 48 V. But, you have to take into account that the balanced BA-3b exposes the speaker to a maximum voltage of +48 V, and minimum of -48 V, and a peak-to-peak of 96 V. It doesn't quite make sense, at first, that a 64 V power supply (+/- 32V) can create 96 Vpp, but it really can because the reference voltage for the speaker is constantly moving rather than being fixed at 0 V. I've missed this detail on paper when dealing with DAC circuits, so I totally understand how others in this thread got confused by thinking of everything in terms of ground-referenced voltages without remembering that the speaker is not referenced to ground.
P.S. You do have to make sure that the +/-32 V power supply can provide enough current.
Old 15th March 2012, 12:00 AM   #135
Zen Mod's Avatar
it's easy
one (plain , common , usual ) channel of amp have 1x power
same amp , with two channels bridged , have - in ideal conditions (or unloaded) 4x power
so - Upp must be 2x
sort of backward thinking , but useful as mental trick ........ before analysis
Old 15th March 2012, 01:18 AM   #136
flg's Avatar
Now is when we need pictures
Or maybe, now is when you go build it and try and measure it. You probably would have to use rms to measure it, and I don't think I'm willing to go there just yet...
The BA-3 your trying to engineer, not the balanced thingy, produces +and- 24Volts out with an input of 1V (Hypothetically). 24Volts maximum, in any language 24V. No 2X B.S. 24Volts peak!
Stop making me bang on my kybd!
You could call that output from 1 BA-3 48 Volts Peak to Peak. But it is still 24 Volts peak. The difference between the 2 terms is one does not take into account the polarity. It is an absolute value of 24 Volts peak! 48 Volts peak to peak is between the 2, as in, the difference.
You could put 2 BA-3s together...
When feeding them out of phase inputs. Did you read that? Go reread it again. When feeding them out of phase inputs, you will still get 24V peak out of each. But then, in differential, or Ballanced mode, if one has a peak 24 Volts positive, and 180 degrees later, 24V negative, it also has the other side producing 24V Peak. The same as 2 seperate amplifiers. Since it has a + and a - input, at the same time, we can, as you did, treat them like a balanced or bridged amplifier. And, call the output 48V peak to Peak. Don't be adding your car stereo buddies 'ol addage of it makes 2X the power or whatever. I'm tellin you, 1 BA-3 produces 24V out, two of'em in balanced/bridged mode would produce 24 Volts out of each, but, out of phase that can be called 48 Volts out. If you feed 2 BA-3s both an in phase signal you get 0, Nothing, Nota balanced or diferential out. Measureing between them will give you paratically nothing! Measureing 1 output to ground would be 24 Volts Peak. Measureing the other output would be the same 24 Volts Peak. In phase they are only in parallel and only current adds.
I left the club after two Martini's I think I needed another...
Old 15th March 2012, 01:42 AM   #137
6L6 is offline 6L6  United States
6L6's Avatar
Yes - that is correct; and you can never have a peak higher than the rail voltage. Being on 'one side' has nothing to do with it.
No. Perhaps that equation is true concerning current, but you can't have a voltage peak higher than the rail.
No. It's impossible to have a voltage higher than the rail.
The losses are real, of course, but that's not actually important in this case. The thing to remember is that you can't have an output voltage higher than the rail voltage. There voltage can't be created out of nowhere -- the voltage has to come from the rail.
Remember that an amplifier is nothing more than an AC oscillator for your DC power supply.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 15th March 2012, 01:49 AM   #138
Please explain how Papa pass got 100 watts as shown in his graph at the beginning of this post.
Old 15th March 2012, 02:00 AM   #139
6L6's Avatar
This is not the whole amplifier. This is the driver portion of the amplifier. To get the 100 watts you need a BA- output stage, (it would be easiest to use the Push-Pull), a bunch of power mosfets, a big power supply, and an enormous amount of heatsinking.
Pass F4
Old 15th March 2012, 02:29 AM   #140
flg's Avatar
And, for this discussion, we are talking about 2 BA-2 output stages, per channel. Yep, 2 more for the other channel. Hmmm, did Nelson say these output stages draw in excess of 300W for 2ch? O.K. this amp is sucking 600W of power even without a signal...
Back to the 24V out of this BA-3X. N.P. ussually talks in 8 ohm outputs. 24V on a bridge loaded 8 ohms is (48V across 8 ohms) 6A (first approximation easy math)??? 6*6*8=288 Watts peak! Is that what you have in mind?
Oh yea, the question was How did N.P. get 100W at the begining of the thread? Were those rms watts or peak watts?
100W/8ohms=(12.5)sqrt=3.535A He got 3.535A through an 8 ohm speaker probably. Might have needed almost 28.3 Volts on that 8 ohm speaker.
Burning Amp BA-3 Backbones Pass Labs 954 14th May 2013 09:51 PM
Burning Amplifier BA-2 Variac Pass Labs 1068 26th March 2013 02:33 PM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Page generated in 0.12624 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
