#2 |
both sources are near gate arrow - so pointing toward gnd
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
Sorry don't follow. Both sources?
#4 |
Q100 have one , same as Q101
#5 |
Have you measured the Idss of your jFETs? A successful Idss measurement shows that you know which legs/pins are Drains.
Since most jFETs are electrically symmetrical, you can swap drain and source and repeat the Idss measurement. This will confirm the gate pin. Now compare what you have determined with the actual manufacturer's datasheet. You should see agreement on pins locations. I failed to follow this through when I first started with jFETs. I didn't blow any, but I got very confused by manufacturers adopting different pin outs. To92 jFETs seem to come in every variety of pin out available. BTW, a 9V pp3/9 battery, a 1k0 resistor and a voltmeter virtually result in a guarantee to never damage your jFETs.
regards Andrew T. Last edited by AndrewT; 18th November 2011 at 11:16 AM. |
#6 |
Hi Andrew. Thanks for your reply.
I have seen the datasheet for the pin outs and have assumed that it corresponds with my fets. What the schematic doesn't show is GDS (like a PCB mask might - but the clone boards don't!) I will check the idss as you suggest. Regards. |
#7 |
Source of Q100 is connected to the Drain of Q101. Pin with the arrow is the Gate.
#8 |
| third input for B1 | 1108 | Pass Labs | 4 | 28th June 2011 06:42 AM |
| B1 question | xecluded | Pass Labs | 19 | 19th April 2010 04:46 AM |
| Help with B1 PSU | pmchoong | Pass Labs | 58 | 1st October 2009 05:15 PM |
| sk30 for B1 | polygon | Pass Labs | 4 | 12th April 2009 05:14 PM |
| B1 Preamp - Help Me! | Professor smith | Pass Labs | 173 | 21st October 2008 03:55 PM |
| Page generated in 0.09179 seconds (74.86% PHP - 25.14% MySQL) with 11 queries |
