Hello,
I suddenly have a problem with one of my aleph 2 Last night, as the amp where turned off, I suddenly heard a loud "ploc", just as if a balloon had just exploded. When I turned on the amps, one of the speakers made a very loud "bzzzzzz". Turned every thing off and had a look inside : nothing looked smoked...took my multimeter and turned on again the amp : looked at the dc offset : 5mv. And suddenly, 40 V !!!!! Took things appart to search a smoked component and found nothing. Put everything together, measured again the dc output : 5 mv, stable over a long time. Wired to the speaker : good music ! Strange, a bit worried, turned of the amp and went to bed. The day after, turned on the amp : "bzzzzzzzz"... Does anybody has an idea where it could come from ? |
#2 |
is this DIY amps?
soon to be: papa's Class A all the way |
#3 |
You're right, i Forget to mention : yes, those are diy amp. They've been runing fine for 4 years. I recently optimized them (dc offset by à better appairing of thé fets), and It worked fine during a few weeks...
#4 |
check all solder joints
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#5 |
do you have pictures and schematics? also for the PSU.
#6 |
Do you have a separate psu for each channel?
I have experienced similar phenomenon with my monster aleph on both channel, when one of the four rectifier diodes went to short circuit. (It has a single psu for both channel.) Gyuri
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat |
#7 | |
Shouldn't happen with standard silicon diodes as these prefer to go open circuit; any case that's a really bad fault - I had that once during testing - and needs a very quick fix. @ndhennin: I agree with Zen on all accounts, sounds a lot like a cold solder joint to me! Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#8 |
Ok, I am going to check all the solders. But I am still a bit worried about the big "ploc" it made at the beginning : where can this noise come from ? it can not come from a solder point...
#9 |
yes it can. if your PSU caps is charged. du you have bleeder resistors?
#10 |
Sounds like you've got a dry / cold joint on one or more of the output devices.
| Aleph x one problem | daltvi | Pass Labs | 3 | 22nd December 2009 10:22 PM |
| Aleph 5 problem 2 | pmchoong | Pass Labs | 98 | 17th December 2008 04:36 PM |
| Aleph-x problem | globalweb | Pass Labs | 3 | 27th September 2006 11:29 PM |
| Aleph-P problem ?? | peter7 | Pass Labs | 6 | 12th July 2005 02:34 AM |
| Aleph-5 Problem | dzkh63 | Pass Labs | 0 | 14th September 2004 02:19 PM |
| Page generated in 0.09653 seconds (78.95% PHP - 21.05% MySQL) with 11 queries |
