Closed Thread
Old 17th November 2011, 10:25 AM   #1
tanker is offline tanker  Sweden
Default The Lidström Lethal AMP -dead simple! :-)
After looking at all these funny amp projects with lamps, high watt resistors among others I decided to post this design idea.
-It can't be simpler! (meta Occam)
It is just an idea and will not work as is, you will need some bias resistors and maybe a cap here and there, but as a design idea it's fun.
If you do know what you are doing, go ahead and play with it.
-If you don't -stay away or die!!
Ps. ZEN, burning amp, 300B and every tube design out there are all safer than this, stick to them if you don't know what you are doing...
Old 17th November 2011, 10:47 AM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
give me same weed you're using these dayz
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 17th November 2011, 11:30 AM   #3
What?
-And I even put a fuse there...
Old 17th November 2011, 12:30 PM   #4
tinitus is offline tinitus  Europe
constructing without mains isolation transformer is forbidden
moderation
Old 17th November 2011, 10:08 PM   #5
Ok, after reading the forum rules I see your point, I will behave...
(Even if the design itself is no different from the PFC part of a modern PC power supply, however unorthodox in audio)
Looking at the (somewhat clearer) schematic below, one can realize that the design is actually isolated from the mains using both in- and output transformers.
I hope you are all still alive....
Old 18th November 2011, 12:02 AM   #6
so, if modern switchmode supply is like this, why not use one, if thats all it takes ?
tho it appears to me that all switcmode supply do have 'isolation transformer'
Old 18th November 2011, 11:04 AM   #7
Now we are a bit off-topic...
In a typical "primary switched psu" all the active componets are on the primary side, without isolation, see picture below.
Galvanic isolation is done after the switching components. On the secondary side of the transformer there are only filter components.
You can build an audio amplifier this way, but it can be a bit dangerous if you don't know what you are doing, because you will have to put active electronic components on the (unisolated) primary side.
Building a large amplifier is a more complicated, you would have to put a PFC (power factor correction filter) on the input in order not to generate noise into the electric power lines feeding the amp.
In this case, building small ZEN like amplifiers that is not an issue...
Old 18th November 2011, 12:21 PM   #8
might be that its not so different from building your own switchmode
but there is one really important big difference
what you suggest is far more simple than building your own switchmode
and you know how it is with simple designs
they also attract the less skilled members
Old 18th November 2011, 12:29 PM   #9
moderation
'tanker' have been told kindly to make his design safe
and was allowed a second shot at it
no point in continuing this way
if you want to proceed with a safer version, please open a new thread
sorry to close it once again, but this will never be allowed
Closed Thread
Simple SE 1 dead speaker & front tube getting very hot very quickly Reidy- Tubelab 1 24th July 2011 02:06 PM
Dead Dead Laser Pickups - why not replacing the Diode only? Salar Digital Source 9 24th January 2010 01:44 PM
cyrus 2 dead c32 & 31 wrong way help paul_peraic Solid State 0 29th May 2008 03:26 PM
Dead simple tube circuit mrjcfreak Tubes / Valves 1 29th June 2004 09:31 PM
My potentially lethal DIY amps Musher Solid State 3 14th July 2002 12:51 AM
Page generated in 0.09799 seconds (77.24% PHP - 22.76% MySQL) with 10 queries
