hi my friends,
I have a problem with my DIY Aleph P1.7 project, that I realizzado using a pcb version mother board on which there is also the volume control similar to that proposed in the original project of big Nelson Pass, with the difference that it is designed on the 128 steps; the relays, which manage the steps, are seven per channel; the resistance values that contribute to the attenuation control are different from those indicated it's original design Pass, and specifically as follows: 267 - 620 - 1.43 K - 3.32 K - 7.87 K - 18K - 43.2 K exactly my problem is the management of the attenuation of the volume, when I start to turn the potentiometer which acts on the controller until you have the first of the first relay switch which is the first step, the audio level is not suited to a night listening ,,, I did all the inspections, which excluded abnormalities mounting components and malfunctioning of the control circuit, I have the feeling that the problem lies in a not correct scale of values of the resistors, what do your think about ? Thanks in advance to all those who will respond to this 3D Gianni |
| FS - Balanced 128-step relay attenuator | lil' knight | Swap Meet | 3 | 10th January 2011 02:31 PM |
| 24 Step Attenuator | poynton | Parts | 1 | 9th January 2008 07:26 AM |
| Alps step attenuator | kmtang | Tubes / Valves | 5 | 30th May 2005 11:51 AM |
| 128 step volume controled by relays | roger-k | Solid State | 4 | 31st March 2004 08:42 PM |
| Page generated in 0.06204 seconds (65.72% PHP - 34.28% MySQL) with 10 queries |
