Old 14th November 2011, 01:16 PM   #1
nar is offline nar
nar's Avatar
Default Aleph_Ono reduce gain ?
Dear all, Wayne and Nelson,
Recently hooked my diy AlephOno with a Rega P3 and an Elys cart mounted on
Volume is too loud, compared to the Ortofon MC3 turbo in the same place, resulting in a less crisper sound layering, with "ear tiring" mediums when playing the record loud. As I experienced also with Pearl II and my Ortofon cart, I needed to reduce stock gain. So I would like to reduce gain for the MM stage of AlephOno in order to match the Elys
My question is how do we calculate it, given the feedback loop is 2 resistors and 3 capacitors and also operates RIAA eq. ?
As 40 dB @ 1kHz is x100, I would like to go and try x50, so about 33,98 dB.
A second question would be : the 32V supply. I changed supply and now it is 30V symmetric instead of 32V. Is it bad, or can I keep it ? the PSU is UGS based, so basically Pearl One regulator but fully symmetric. I can finetune the voltage up to the 32V originals if needed.
Thanks for your answers,
Best
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright
Old 15th November 2011, 04:54 AM   #2
6L6 is offline 6L6  United States
6L6's Avatar
When you have the phonostage adjusted for the Elys cartridge, I will bet you a bottle of your favorite whiskey that you won't like it... (The cartridge, not the adjustments to the AlephONO)
Old 15th November 2011, 06:13 AM   #3
nar is offline nar
nar's Avatar
Lol, I know, I'm not really fan of Rega's products, with the Elys there is actually same output level from MM stage than CD version ...
But the AlephOno is at my brother's and we found that sonically, there was a problem with mediums when playing a LP loud. When listening @ more confidential levels it goes Ok, so same thing I encountered with Pearl II and Ortofon MC3 turbo. I ended up doing the gain mod and everything went in place.
Now, I'd like to do the same on AlephOno. In order not to mess up with a bad eq. setting, i thought about setting R21 to 50R instead of 100R ... it would perhaps keep the eq. curve the same whilst lowering gain ???
Best,
nAr
Old 15th November 2011, 08:20 AM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
don't do this
put 10K multiturn pot between drains of 2SK389
if needed - put drain resistor on right Jfet
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 15th November 2011, 12:03 PM   #5
nar is offline nar
nar's Avatar
Originally Posted by Zen Mod View Post
don't do this
Thanks for the input. I thought altering drains figure would only cut in OL, not in closed loop gain ? Maybe i'm mistaken.
Best,
nAr
Old 15th November 2011, 12:41 PM   #6
Zen Mod's Avatar
uff
sorry - my brainfart , probably because of not sufficient speed of caffeine going in my system
it was long time ago when I was playing with RIAA networks , and now I even forgot what I wasn't knew then , let alone that I can't remember what I knew
anyway - it's easy : just calc impedance of RIAA chain for 20, 50, 1K , 20K , then calc what db ratios between extremes are when divided with regular value of R21 and altered one .
hmm ..... lemme see if I can calc that on back of napkin ....
yup - for 6db decrease of gain , you need to increase feedback for same amount - so you need to increase R21 for 100% and you'll be in ballpark
so - take 200R for start
fine tuning of circ will still demand reverse RIAA filter , and any of common methods for freq sweep
I reckon that 20Hz will be 19,27db above 1K , which will be around 19,9db above 20K ; that's quick and rough calc
Old 15th November 2011, 04:42 PM   #7
nar is offline nar
nar's Avatar
Thanks Zen Mod
nAr
Old 16th November 2011, 08:29 PM   #8
wayne is offline wayne  United States
How much lower gain do you need?
Old 16th November 2011, 08:42 PM   #9
Zen Mod's Avatar
nar wrote in post #1 :
Old 17th November 2011, 07:06 AM   #10
nar is offline nar
nar's Avatar
About 34 dB
Best,
nAr
How to reduce the gain of the symasym 5_3? formula 22 Solid State 0 20th September 2011 04:13 PM
How to reduce gain in mu-follower? karsten21 Tubes / Valves 9 30th June 2011 10:31 PM
Transformer based voltage gain + unity gain stage? soundcheck Solid State 2 10th August 2010 02:44 PM
How to reduce gain of this Tube Preamplifier ? ANALOG GUY Tubes / Valves 5 22nd September 2006 03:37 AM
Reduce Input Gain Question? mgreene Chip Amps 9 27th April 2004 11:32 AM
Page generated in 0.11188 seconds (81.02% PHP - 18.98% MySQL) with 11 queries
