#71 | |
2) There is AFAIK no transformer output version of the Donut, as I find that straying just a bit too close to something Choky would like (hollow state). 3) The schematic is not published the usual places, as I for one am done supporting rip-off artists. The same goes for the fluffy Serb. If we feel somebody is genuine, and so forth, we hand out schematics, usually followed up with help and advice. 4) ......and yes, the Donut is made by me, with (great) support of Choky, a bunch of other less fluffy Serbs (you know who you are), a nationality confused Frenchman, a Dutchman, a German, and a couple of Americans, so actually there are a whole bunch of Donut creators. Sadly, there is only one Donut owner/builder (till the fluffy Serb gets going). Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#72 | ||
I should add another item to my NICE-TO-HAVE FEATURES: C) Current Output Stage (hopefully as an option, since I don't know yet whether my speakers will like this) Seems to me that a current output amplifier would do best when the speaker is the only load, but this area of amplifier operations is the newest concept for me. Quote:
Hand in hand with "not feeding the IP rip-off artists," I also see a theme here on diyAudio that veterans don't do a lot of hand-holding with newbies. The ethos is that DIY folks should learn by doing, and not have every answer provided without requiring at least a little thought. I actually had a mind to build my amplifier without ever sharing. You'll note that I did not include resistor values on my schematic (partly because they haven't been dialed in yet). My primary reason for putting my schematic here is that I plan on making some boards, and given the minimums required, I might as well share them with other interested folks. Thus, it seems prudent to share my design before I make the boards so that folks have a chance to make suggestions for a reasonable amount of flexibility. One thing I decided to do after reading Choky's comments is to put degeneration source resistors on the input JFETs, and capacitors on the inputs, even if I have to solder wire jumpers in the event that I decide I don't want them. I'd rather solder jumpers than cut traces and have a mess. P.S. I read every page of Bob Cordell's book, enjoyed it immensely, but was not interested in building anything but Class D. Funny that my two DIY interests turned out to be Class A balanced SE SUSY and Class D, spanning the spectrum from fairly inefficient to highly efficient. The Class D amp would go in my electric car for longest battery life, and the Class A would go in my main, stationary listening position. Maybe in my next update I'll restate my goals, requirements, and other features I'm interested in, just to be clear. I've mentioned almost everything I'm looking for so far, but my comments are rather spread out in this thread. |
#73 |
If you don't know, the most likely answer is not.
Looks like Sponge Bob has killed another thread. |
#74 |
Ah, well, I am willing to rip out the crossovers. In fact, these speakers are designed for normal wiring, bi-wiring, and bi-amping. Conversion involves changing or removing the crossover. Apart from a lack of schematics for the crossovers, there's nothing stopping me from doing a little homework to see what changes would be needed for driving them via current output.
I hope I am not being too naive when I believe Nelson when he says that speakers react most directly to current, not voltage. Thus, with proper connection, any speaker should work, provided you're willing to alter or remove the crossover. I should read those articles again, though... My plan is to bi-amp these speakers eventually, since I have at least 8 DAC outputs available. The DAC has non-volatile memory for various DSP effects, so I could program in the appropriate active crossover frequencies and have them available immediately upon power-up. If I can successfully build one amplifier, I should be able to build four or five. |
#75 | |
So what is the point of using an inductor as load VS. a CCS you might ask? It is so that if you want real class A, as opposed to pseudo class A, you will end up with a huge power demand, offering a relatively limited power output. Now if you go with a CCS, the effort needed for heatsinking and PSU, is going to be massive. Using an inductor, makes those demands much lower, as in less than half, for the same output. The other solutions like active current source, are still in the pseudo class A category (let the flaming begin), and in comparison quite dull IMHO. I have built quite a number of amps over the last 15 years, starting out with class AB PP, over single ended class A, and balanced single ended class A. Of those, most of them have been built in many iterations, testing among other things current output, transformers, SUSY, you name it. The only way to find out what really pleases you, and fits your speakers, is to experiment. Mostly current output only works well with full range drivers, but can also be of benefit with band tweeters. The Donut can easily be configured to run as current output amp, so makes no big difference to the amp choice. In your shoes, I'd build a simple Zen V1 , a Aleph, an AX, a Zen 9, and a Zen 7. Play around with them, and find out what pleases you, and find out how to reach that goal. The Donut is made to please me. It fits my speakers well (full range horns), and that's pretty much it. It was never the intention to make an amp that anybody else likes. Magura
| Complementary JFET-JFET cascode input, BJT VAS-Drivers, Lateral Output | Neutrality | Solid State | 53 | 23rd October 2011 06:53 PM |
| I love jfet input | Tekko | Solid State | 10 | 21st October 2011 08:40 AM |
| FS: PreAmp with Complimentary JFET Diff input & JFET ouput | USAcircuits | Vendor's Bazaar | 12 | 21st June 2011 11:02 AM |
| discrete jfet input opamp | rubydac | Solid State | 5 | 12th March 2008 04:59 PM |
| ZV7 Input Impedance. | gl | Pass Labs | 0 | 15th February 2005 10:54 PM |
| Page generated in 0.11821 seconds (83.35% PHP - 16.65% MySQL) with 11 queries |
