Old 17th November 2011, 05:06 AM   #31
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
just re-solder all these pads properly and do not worry
it was good for years , it will be good for few more
or - if that's too much of a burden for you , you can always send that bad amp to me , for proper disposal
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 17th November 2011, 05:36 AM   #32
Dukja is offline Dukja  United States
OK, I'll resolder it when the caps come in.
Bear with my ignorance, why is that pad so hot? I don't think the heat came from the NTC. It seems to be from the pad itself.
Oh, this is no burden to a senior research engineer at all. This is just a hobby. I only need to get my feet wet. I just plan to dig out my microelectronic textbook to have some fun. And you had enough fun already.
Thanks a lot for helping!
Old 17th November 2011, 05:50 AM   #33
Zen Mod's Avatar
hot pad - sort of chicken-egg dilemma
NTC is heating all the time that poor pad - solder is getting worse all the time , contact is getting worse all the time etc.
in fact - nothing to worry about , especially when you bring it back to proper state
Old 17th November 2011, 06:01 AM   #34
That make sense to me and was what I suspect. Maybe the pad can use some mini heatsink later.
And I do feel some 22mF cap a little budged at the top. Thanks a lot for all the help. This give me motivation and some expectation to restore this Aleph 3, if it already sound so good at current state.
You and others are great guys here and fun to talk to.
Old 17th November 2011, 01:37 PM   #35
ungie is offline ungie  Canada
Given the internal heat generated in these amps, I would recommend that whatever power supply caps you choose should be rated 105degC NOT 85degC.
Old 17th November 2011, 02:17 PM   #36
Yea, I saw the cap temperature was pretty consistent around 105F after turning off for few minutes. So it may be a good idea for the longevity.
Old 17th November 2011, 03:01 PM   #37
KatieandDad's Avatar
That's VERY WARM for electrolytic caps. They contain a jelly after all and the jelly will dry out if they get too warm.
I'm concerned that my F4 runs at just under 50 Degrees C.
Old 17th November 2011, 07:53 PM   #38
105 deg. F = 40 deg. C
I was messed up unit so actually 85C cap should be good enough.
Are you also confused by C & F?
Old 17th November 2011, 08:30 PM   #39
grimberg's Avatar
When replacing the caps, look for 105°C. Something like this one, if it fits in the same physical space:
Digi-Key - P10635-ND (Manufacturer - ECE-T1HA393FA)
Don't feel bad about getting confused by different systems, even rocket scientists do it some times.
NASAs metric confusion caused Mars orbiter loss - CNN
Old 17th November 2011, 09:09 PM   #40
JoelS is offline JoelS  United States
not that there's anything wrong with replacing all the caps in your amp, but if you want to save a few bucks you might try replacing the small caps first and see if that solves your problem. the smaller DC blocking caps in the signal path will cause a loss of low end when they start going bad, which sounds like the problem you started describing. when the big filter caps in the power supply go bad it will cause hum and buzz problems in your audio due to ripple appearing on the power supply rails.
-Joel
What to do after i finish recap? rg12 Parts 13 8th September 2010 10:43 PM
Exposure 8 recap EddieB Solid State 0 2nd February 2010 09:04 PM
To Recap - A Question Family_Dog Tubes / Valves 5 29th May 2006 08:22 AM
my little Aleph3 moamps Pass Labs 16 27th August 2003 09:48 PM
Aleph3 HarryHaller Pass Labs 13 7th February 2002 02:46 AM
Copyright ©1999-2013 diyAudio
