Old 31st October 2007, 11:48 PM   #101
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by jleaman
Why would you spend and build a Mini A for a headphone amp, that does not make sense to me.
because
of this
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 1st November 2007, 12:37 AM   #102
d to the g's Avatar
Originally posted by GRollins
When only the very best will do...
Grey
the 6moons article was pretty telling.
Old 2nd November 2007, 04:46 AM   #103
winslow is offline winslow  United States
I want to build one of those one day.
That and a Pumpkin in one kit. Nice integrated kit right there.
Originally posted by Zen Mod
because
of this
Old 2nd November 2007, 05:42 AM   #104
Zen Mod's Avatar
that will need lots of case .........
Old 7th November 2007, 10:54 AM   #105
ssmith is offline ssmith  France
Default Mounting air core inductors?
Hi again,
re my previous question re coupling, managed to figure it out.
However wondering if anyone would mind taking the time to look at my layout.
Everything has been wired up since and is working fine -- although there are just a couple of things that are bugging me right now -- a high frequency buzz only detectable when volume is at max, and a very very slight hum -- again only audible when the ear next to speaker.
I suspect I may have run into an issue mentioned in the aleph-X wiki, that Magnetic fields from inductors may also be a concern, especially for air-core inductors, so give due consideration to mounting and shielding.
My diy'ed inductors (0.9mh, DCR 0.2 ohm) are enclosed next to the caps. But the tubing and cap enclosing them is aluminium. I presume that this provides inadequate or no shielding? When powered on, there is also some vibration from them, so I think I will have to damp them too (what is recommended, filling the enclosure with sand, varnish?).
Finally, the steel mounting bolt goes through the centre of the inductor. Could this cause a problem? -- I could alway change it to a plastic mounting bolt.
My rails are at about 21.7v and after an hour or so the heatsinks are 'crikey hot' (5 seconds hands on), so I may add a resistor to make the PSU a CLRC, just to drop the rails a bit more. PSU is running two channels, each biased at 2A.
thanks in advance.
Old 7th November 2007, 11:11 AM   #106
Zen Mod's Avatar
Default Re: Mounting air core inductors?
Originally posted by ssmith
Hi again,
temporary replace chokes with resistors - if buzz is gone - there is culprit ;
same for steel bolts ; sometimes they are bad , sometimes not ; try without them and you'll know
Old 7th November 2007, 11:19 AM   #107
Zen Mod,
Thank you.
Old 21st January 2008, 03:54 PM   #108
posxia is offline posxia  China
my dear DIY brothers, I found some old IRF120 in the electric market, It can work well in MINI-A £¿their packing are TO-3.
hahaha ,I like TO-3 packing ,especially in class A amp.
Old 21st January 2008, 04:02 PM   #109
some datasheet about IRF120.PLS give me some advice.thanks!
Old 25th January 2008, 04:23 AM   #110
The voltage is fine, but the current looks to be a little scant, particularly if you have a lower impedance load. It might be a good idea to parallel two sets of outputs, or perhaps even three.
Grey
Mini-A PCB'S sandstorm33 Pass Labs 3 23rd March 2008 11:39 PM
the Very Mini Magico Mini zei Multi-Way 7 11th February 2008 08:10 PM
My new mini-A. I really like it! mpmarino Pass Labs 20 3rd August 2005 02:37 AM
New Mini MikeW Pass Labs 39 7th June 2004 02:10 PM
Page generated in 0.11571 seconds (79.82% PHP - 20.18% MySQL) with 11 queries
