Old 6th November 2011, 06:32 PM   #1
buzzforb's Avatar
Default Seperate PSU Pro/Cons
As the title states, what are the pros and cons and are there any tips on setup if going with standalone PSU.
Old 6th November 2011, 06:58 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
hefty connectors ; Speakon possibly?
CRC or CLC ; final C in case with amp electronics
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 6th November 2011, 07:10 PM   #3
Yes, final C in the amp case.
All the high pulse charging currents kept beside the transformer.
regards Andrew T.
Old 6th November 2011, 07:19 PM   #4
buzzforb's Avatar
Excellent. SpeakOn is the connector of choice. Whether to put part of the filtering inside amp case was a big question. If using regulated supply like Juma did in his 2sk2013/J313 F5, does this stay with the Trafo since it is doing a lot of the filtering. Is it more ideal to have multiple small caps as last C in CRC making for easier load. what about noise pickup on cables? I have been looking at 4c cable usually reserved for speakers, but it is unshielded.
Old 6th November 2011, 07:30 PM   #5
Zen Mod's Avatar
reg - whatever is easier for you , but better integrated with amp
multiple caps - usually better , but not if comparing big good ones and small bad ones
shielding is not necessary at those levels of current ( if I resume well that we are speaking strictly about power amps )
Old 6th November 2011, 08:45 PM   #6
albertNL's Avatar
What about this?
ÖLFLEX® CLASSIC 100 CY-lappbenelux.lappgroup.com
Old 6th November 2011, 08:50 PM   #7
Zen Mod's Avatar
good one
especially because shield can be used also for transferring safety earth to amp case
Old 6th November 2011, 09:12 PM   #8
buzzforb's Avatar
I have found some others that I am looking at. Sourcing that fine looking cable would probably be difficult.
Old 6th November 2011, 10:21 PM   #9
albertNL's Avatar
We just bought 50m
ÖLFLEX CLASSIC 100 CY 3G2.5 at work. Besides using it at work, I plan to use it for power cables and internal cabling (power entry to transformer).
I know Farnell sells some types of Lapp cable. Not sure if they sell this one.
Old 6th November 2011, 10:26 PM   #10
albertNL's Avatar
I just typed Brlington, NC in the dealer locator box at Lapp USA and found seveal dealers in you area.
Welcome to Lapp Group North America - your partner for high performance cabling solutions! The Lapp Group is one of the leading supplier of cable, wires and cable accessories.-Lapp USA-lappusa.lappgroup.com
Good luck!
Pro vs hifi drivers - pros and cons? Defo Multi-Way 992 14th April 2012 12:51 AM
Quasi-complimentary; pro / cons? Cobra2 Solid State 69 16th May 2006 02:12 PM
quasi complementary amps pro and cons? tubesaurus Solid State 3 27th April 2006 01:35 PM
Pro and cons high DCR filter choke reaction Tubes / Valves 6 20th March 2006 08:24 PM
Page generated in 0.09170 seconds (79.76% PHP - 20.24% MySQL) with 11 queries
