Pass Labs Xs - Page 34 - diyAudio
Old 3rd March 2013, 08:45 PM   #331
The one and only
Nelson Pass's Avatar
The patent cited shows essentially the circuit of the X600. Many alterations
have occurred since those days, so you don't want to be relying on that
particular diagram.
Old 3rd March 2013, 08:47 PM   #332
buzzforb's Avatar
particular diagram.
Nelson,
Any hints on the B4 alterations. My proposed cheap clone apparently is getting further from the truth.
...Shape the sound , Man!
Old 3rd March 2013, 08:47 PM   #333
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
ah , so
then you know right addy for asking what will be difference between old Kalifa and new Kalifa
btw. your place is where buzz is
edit - just saw that Olórin speaket his word , regarding susy-fying da Universe
(and back)
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 3rd March 2013, 08:55 PM   #334
buzzforb's Avatar
Originally Posted by Zen Mod View Post
ah , so
(and back)
You know me. Always chasin my tail
Old 3rd March 2013, 09:53 PM   #335
particular diagram.
Thanks Mr. Pass. To me, Ultra-Symmetry [TM] says for every one polarity device there is its complementary. F5 fits this definition. And every F5 [in this model] has an identical twin be fed with out of phase twin input signals.
Best regards.
Old 3rd March 2013, 10:18 PM   #336
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Antoinel View Post
custom-made Speakon cord.
Uhn-Uhn,
suppose you have a 4-quadrant output stage in the top floor, consisting of 2 Push-Pull OS's, makes 4 banks of output devices.
The Massive current sources are in the lower section, 2 banks of power devices.
Each of these is in parallel with 1 bank of OS devices in the top, to provide the SE current.
Which is in Short Hick's how the "regular" models are layed out.
Now, if these are set-up as constant current sources, they do not require an (audio) signal from the UGS6 board.
One side of the current source is connected to a rail, which is in the bottom section, the other connection is with the output in the top case.
Bottomline would be that the 50-50 split of the electrolytic cap banks is merely physically motivated, not enough room in a single case.
Mains enters in the bottom case, to the toroidal and the rectifiers, then out goes to the 1st lytic banks, and through the umbilical to juice the other six-pack (Xs-150).
Additional connectors in the umbilical would be for the ground connection between the top and bottom cap-banks, plus the 2 links from the L/R top outputs to the current sources downstairs.
Makes a 5-wire total, and Zero need for a Heavily shielded coaxial inside.
With an 8-wire cable :
- 2 in parallel for the Positive rail
- 2 in parallel for the Negative rail
- 2 in parallel for power Ground
- 1 for the Left current source connection *
- 1 for the Right current source connection *
* = less current
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
Old 3rd March 2013, 10:52 PM   #337
Zen Mod's Avatar
xformers ?
who need stinkin' buzzin' xformers ?
direct mains connection is for fearless Amp Bui/ahem/ers
so - that'sthe way - XS is , in fact , Circlotron , with cascodes in OS
Old 4th March 2013, 12:48 AM   #338
jacco vermeulen. We are thinking about Xs, and will understand this puzzle. The objective is to understand this state of the art/science which Mr. Pass believes as expressed by viable schematics, measurements, etc.
  • What is the simplest schematic which describes Xs. Let us ignore for the time being cascoding, parallel devices etc. Let's nail down this schematic first. We know that it uses a constant and not a modulated current source in the output stage. A modulated current source maybe the next generation Xs.
  • What is Ultra Symmetry? Two neutrons or two stable atoms are Ultra Symmetric. Each similar pair is an exact 3-D mirror-image [twins]. It take two identical entities [at least] to express ultra symmetry. Others may have other examples of it.
Best regards
Old 4th March 2013, 01:01 AM   #339
buzzforb's Avatar
Cups too full. Step away for a while and listen to some good musak, preferably with transformers.
Old 4th March 2013, 01:29 AM   #340
The one and only
Ultra-Symmetry is just a trademark. I don't currently have a product described
as this.
Pass Labs amp combination for Thiel speakers, need Mr Pass' advice ! And everyone... JulienG Pass Labs 82 6th July 2015 03:41 PM
HELP to Pass Labs D-1 maikl 5 Pass Labs 3 16th May 2011 04:53 PM
I need Crown XS-500 service manual or schematic (XS-500, -700, -900, -1200) timbert Solid State 0 30th March 2009 07:52 PM
EXECUTIVE AUDIO XS 402 and XS 602 POWER AMP SCHEMATICS alexclaire Solid State 1 24th March 2009 08:41 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
Copyright ©1999-2017 diyAudio
