Pass Labs Xs
Pass Labs Xs
Old 26th February 2013, 01:42 PM   #251
Antoinel is offline Antoinel  United States
Pass Labs Xs
Originally Posted by jacco vermeulen View Post
Thanks, Mr Colburn
(dad)
jacco vermeulen. Eight poles for a maximum of eight individual wires.
  • a + Vcc rail
  • a -Vcc rail
  • a common power rail to go with the above 2
  • two current source [load] rails
  • Three conductors TBD
Take a look at the link of the first post; picture of the amp on the side of the handles.
  • The bottom box shows a 3 conductor AC power male socket.The Xs literature talked about bigger and quieter transformers and "a bank of soft recovery diodes".
  • Anothe cable connects this box to the one atop it.
  • On the left side just under the handle of the top box may be an independent earth ground for this chassis.
  • Four speaker outputs; 2 black and two red. Speculation about the topology of the output stage{s} is welcome.
  • Maybe two RCA-style connectors under the right handle.
  • A multi-hole socket at the ~top center
  • And the Speakon.
NB. Zen Mod got to it first. Thanks ZM.
Old 26th February 2013, 01:45 PM   #252
buzzforb is offline buzzforb  United States
buzzforb's Avatar
The butler, with the candlestick, in the library.
...Shape the sound , Man!
Old 26th February 2013, 01:48 PM   #253
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Pass Labs Xs
que?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 26th February 2013, 02:02 PM   #254
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Signal Ground.
My problem is with the 2 wires SE.
They go into High Ganja impedance (you know : MOSFET gates. Regardless of a bank of 3W Panasonic resistors in parallel, to side-rail the output)
Those +/- rail conductors carry large bags of current weeds, just think how high the charging peaks to the penthouse cans could reach.
And all those run side-by-side over a 5ft length, inside 0.8" diameter cable.
That's some fancy cable, please name me one that'll do the trick.
(btw, the Speakon only comes in 2, 4, and 8-pole. Using an 8-pole not necessarily means 8 conductors)
Old 26th February 2013, 02:11 PM   #255
(btw, did you notice the F5 output device glue-on thingy in the Xs)
Old 26th February 2013, 02:18 PM   #256
Zen Mod's Avatar
Pass Labs Xs
you're too old for ...... and too young to die ......... so why you should be so puzzled with welder ?
these 8 contacts can be shared for 4 conductors , and these you have plenty of types , even skinned as preputium graded snake
so , what's the fuss - PL guys already revealed where the Troops are , how many dust biters and how many horsemans
what probably will stay undisclosed is what's on now nice and small Greenfield , contrary to Stadium sized proto specimen
so - even if one is Schwarzie enough to put up for two TIG cases (with or without oxygene bottles ) , there is still question mark about wire feeding brain
Old 26th February 2013, 02:22 PM   #257
Zen Mod's Avatar
Pass Labs Xs
you remember that I told ya that Pa deliberately didn't allowed me near his Ark ?
so - fact is simple - Pa found last year ( in Ark, where else ) big stash of various valued glue-on thingies , so now he must find a way to use them all
Old 26th February 2013, 02:53 PM   #258
Pass Labs Xs
Thank you jacco vermeulen for the close-up picture of the signal ground and negative ground labels. Unfortunately, I am disconnected from your question re F5. Dunno the answer.
Most important is that the Xs amp system works safely [first] and performs beautifully. I wonder if there is an answer in a twisted pair of conductors carrying in and out of phase large or small currents to address your earlier questions.
Old 26th February 2013, 03:08 PM   #259
Pass Labs Xs
Signal Ground.
I do not have a clear mental of the "circuit" above. A reference to a published schematic by Mr. Pass will help.
Old 26th February 2013, 03:14 PM   #260
Originally Posted by Zen Mod View Post
too old for lobotomy and too insane to die
Maybe because my flavor ranges from operation mode to cable code, from manufacturing to logistics, and from cost calculation to modular/standardising percentages.
Not just how to actively/passively force the steering wheel to the right on a tilting road (or electronically make front wheels communicate).
Likely why Pa(jammy) tale-chasing hasn't turned yawning yet, 28 years coming august.
(audio is also a better stimulant than sniffing coke during wuthering lows, saves plenty mulla on couch bills)
Ganja candy spit in the 150 =>
Pass Labs XsHide this!Advertise here!
Pass Labs amp combination for Thiel speakers, need Mr Pass' advice ! And everyone... JulienG Pass Labs 82 6th July 2015 02:41 PM
HELP to Pass Labs D-1 maikl 5 Pass Labs 3 16th May 2011 03:53 PM
I need Crown XS-500 service manual or schematic (XS-500, -700, -900, -1200) timbert Solid State 0 30th March 2009 06:52 PM
EXECUTIVE AUDIO XS 402 and XS 602 POWER AMP SCHEMATICS alexclaire Solid State 1 24th March 2009 07:41 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
