Pass Labs Xs - Page 23 - diyAudio
Old 26th February 2013, 12:11 AM   #221
buzzforb's Avatar
Taking f5t as example, the common connection between rails is not made until main case. There it is attached to E, with or without ground lift.
...Shape the sound , Man!
Old 26th February 2013, 12:27 AM   #222
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
sorry , also irrelevant
whatever - if one is going to learn something , must is to decipher exact number of rails in that umbilical
whatever , as soon we reach that point , I'm going to un-subscribe from thread
there is a thin line between learning curiosity ....... and public re-engineering , and from some point there is no such line
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 26th February 2013, 12:28 AM   #223
The one and only
Nelson Pass's Avatar
There are two rails.
Old 26th February 2013, 12:32 AM   #224
Zen Mod's Avatar
trick must lie in definition of rail
Old 26th February 2013, 01:00 AM   #225
Default Amplifier
Originally Posted by PSz. View Post
BA3 seems to be a minimalist expression of the philosophy found in the XS amps. Any thoughts?
The schematic of this Amplifier was inspired by the literature of Pass Labs for its Xs amps, and the contributing literature of DIYers in this thread. Image1.jpg shows two side-by-side schematics of BA3 Front End amplifiers [cut and paste]. Their setup is meant to be balanced push-pull. Play this game with me. Partition the page into 4 quadrants care of 2 orthogonal axes smack in the middle of the page. Assume there is the highest degree of matching among/between components having the same function; e.g Q3 of both amps etc . Note the following:
  • Top right and left quadrants circuits are mirror images; identical performance.
  • Ditto for bottom right and left quadrants circuits.
  • The top and bottom right quadrants circuits have identical complementary symmetry performance.
  • Ditto for the top and bottom left quadrants circuits
  • The top right and left quadrants circuits have identical complementary symmetry to the bottom right and left quadrants circuits.
  • The circuits in the top right and bottom left quadrants have identical complementary symmetry performance.
  • Ditto for the circuits in the top left and bottom right quadrants.
  • I modeled both BA3 Front End amps with the triangles above them.
This total amp circuit [Amplifier] has a high symmetry and a high identical complementary symmetry. Take a look at the second picture Amplifier1A.jpg. Note the following:
  • Both amps have identical out of phase input and power output signals.
  • Note the feedback loops. The power output signal of the right amp is the feedback signal to the left amp. Simultaneously, the power output signal of the left amp is the feedback signal to the right. Each amp accepts this reality because of the system's high symmetry.
I do not imply or mean that the above pertains to the Pass Labs Xs amps in any form, way, or fashion. Just inspiration!
Best regards
Old 26th February 2013, 01:11 AM   #226
buzzforb's Avatar
Never fear. With each revelation, i only get further and further from the truth. I am home now, after 11 days. Time to disappear for a while.
Old 26th February 2013, 01:30 AM   #227
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by dazed2 View Post
Are you sure thats not the 8 pole Speakon?
Not very rational, it doesn't make much of a difference inside the connector.
Why put both signal and power through a single cord, just as easy to use two.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 26th February 2013, 01:44 AM   #228
Originally Posted by buzzforb View Post
I thought earth had to be carried to every case.
For the "earth" carrying case : couple of decades ago I made a 2-case monaural class A power amp with fully regulated rails.
Based on the 50W MOSFET l'Ampli Fou (= crazy amp) design in l'Audiophile by Hephaistos. Aka Gerard Perrot of Lavardin audio in France.
(already had it in my head a couple of years before I read the article, figured it not such a bad idea after-all when I saw someone else do it )
Same principle, one case with transformer/caps and regulation stage, umbilical cord to the amp case. Second case earthed to power ground, worked fine.
(but hey, guessing is 99% of the fun, and I've been spanked by his highness before)
Old 26th February 2013, 03:17 AM   #229
dazed2 is offline dazed2  Canada
Not talking about rationality here. Just that I don't think its a PowerCON thats on it.
To me it looks like a SpeakON 8 pole connector. Doesn't mean Papa used all the taps,
but that he can use more than just 3 wires.
Or perhaps that the SpeakON connector allows for 50A current but the PowerCON allows for only 32A
Old 26th February 2013, 03:43 AM   #230
Oops, my bad.
You're correct, it's a Speakon, they even read Liechtenstein on the Xs pictures.
Smarter choice too, as the current rating is per contact.(30A rms x 8 beats 32A x 3)
The story was more about the 2 cases, and why.
Both amp cases are identical, the heatsinks are identical.
If all power devices were part of the output stage, 56 of them would be in either case, not 40 bottom and 72 on top.
An umbilical with 2 signal wires, one power ground and +/- power from bottom to top, plus output wires, makes no sense.
2 contacts in parallel for the positive rail, 2 for the negative one, and 4 in parallel for power ground does.
Pass Labs amp combination for Thiel speakers, need Mr Pass' advice ! And everyone... JulienG Pass Labs 82 6th July 2015 02:41 PM
HELP to Pass Labs D-1 maikl 5 Pass Labs 3 16th May 2011 03:53 PM
I need Crown XS-500 service manual or schematic (XS-500, -700, -900, -1200) timbert Solid State 0 30th March 2009 06:52 PM
EXECUTIVE AUDIO XS 402 and XS 602 POWER AMP SCHEMATICS alexclaire Solid State 1 24th March 2009 07:41 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
Copyright ©1999-2017 diyAudio
