Pass Labs Xs
Pass Labs Xs
Old 25th February 2013, 04:04 PM   #191
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Rightly so, buyers of the top-dollar drawer do not favor their items on nude display at the giftshop bottom shelf.
On the other hand, fur coats are interesting only if the hurd recognises the animal outside, or outside animal.
(con-fck-you's uncle of Chinese restaurant in CanCun't barrio says : beware of pro-phat bearthing gifty words, if he raps tongue around several enchiladas)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 25th February 2013, 04:55 PM   #192
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Pass Labs Xs
Originally Posted by Antoinel View Post
Mr. Pass. Is Cascode Modulation Cascode Local Feedback?
If you hang out in the Solid State forum, they will be happy to explain to you
that everything is feedback. That said, whether it is local depends on how
far away from which it came.
Old 25th February 2013, 05:01 PM   #193
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Originally Posted by jacco vermeulen View Post
Actually, I just finished watching Maximella, the lezzy vampire slayer.
Loosely based on Claydon's '09 epic work, but filmed in an art-decoish setting, very mondain and plushy storyline (sponsored by Kleenex, so I gathered).
A masterpiece of cinematography, and highly relaxing.
http://www.diyaudio.com/forums/analo...ml#post3380355
May I remind you that whaley spent a lot of time monitoring the skunks of A'dam.
(& wanders off across Frisco all night, after each Simovich limo service drop-off)
A large part of the gay female circle has elements of Tran-Sylvia.
For Xs info, takes patience and sticking a finger through the cage, hoping it will be squeezed for ripeness.
Are you leaking next bond film. Goldfish.
...Shape the sound , Man!
Old 25th February 2013, 06:18 PM   #194
Antoinel is offline Antoinel  United States
Pass Labs Xs
Originally Posted by Igor View Post
The Front End circuit of the Xs amps was designed by Wayne Colburn. It is similar to that in the XP-30 Preamplifier.
Old 25th February 2013, 06:30 PM   #195
hm4nine is offline hm4nine  Europe
No, I don't believe this.
IMHO there is an UGS6-module inside of XP30.
May be the Xs-PreAmp has a similar circuit topology like the front end of Xs-PowerAmp
Old 25th February 2013, 06:42 PM   #196
Pass Labs Xs
I was just informing what the link reported. Its OK which came first; the XP-30 or Amp Xs; as long as their circuits are similar.
Old 25th February 2013, 07:12 PM   #197
Originally Posted by buzzforb View Post
Are you leaking ?
My long-experience with Papa is that things turn out way simpler than initially thought. (simpler not interchangeable with simple)
Another acquired finding, from observations over recent decades, is that the most basic and least pretentious often better describes the most complexed of matters. (cerebral jump : in time, gossip tabloids and low-budget movies indeed show reality clearer than e.g. the NYT and Oscar winners. MiB)
Example, the Xs shows plates and wires (few plates, many wires)
You find the aluminum plates interesting, but not the wires that run directly from each pole (much more on the 300, than in the Xs-150)
Xs for X-Special, or X-simple ?
(more the type to stand in line at the box office, in a trenchcoat with a skunk fragrance, looking at bottoms)
Old 25th February 2013, 07:15 PM   #198
Pass Labs Xs
You still have some J313/K2013 then ?
jacco vermeulen. Post #94 by Zen Mod showed the clearest picture of the PCB entitled "Concept Amp R0, 2009 Pass Labs; Made in U.S.A. Each of the twenty above TOSHIBA Complementary Enhancement MOSFETS MAY reside on its private small heat sinks thereon. At the center of this PCB appears to be an interesting find. There are many resistors lying in the plane of the PCB; but most importantly note those 6 upright rectangular components [ black] among them. Each rectangular component has 6 legs; clearly labeled on the PCB as G [2] and D [2] Thus each rectangular component MAY be comprised of two similar or complementary TO-92 JFETS; glued together; possibly for optimal thermal tracking and/or boosting Idss.
Best regards
Old 25th February 2013, 07:26 PM   #199
I call them 7-legged trenchcoats.
(each 3 in-line stare at the same window display)
Old 25th February 2013, 07:36 PM   #200
Pass Labs Xs
Also note the six tallest blue rectangular components on the PCB; taller than the trimpots. They maybe capacitors. I accidentally stumbled on their look alikes on the chipamp.com site. They were 0.1 uF polymer as shown in the LM3886 chip amp kit.
Pass Labs XsHide this!Advertise here!
Pass Labs amp combination for Thiel speakers, need Mr Pass' advice ! And everyone... JulienG Pass Labs 82 6th July 2015 03:41 PM
HELP to Pass Labs D-1 maikl 5 Pass Labs 3 16th May 2011 04:53 PM
I need Crown XS-500 service manual or schematic (XS-500, -700, -900, -1200) timbert Solid State 0 30th March 2009 07:52 PM
EXECUTIVE AUDIO XS 402 and XS 602 POWER AMP SCHEMATICS alexclaire Solid State 1 24th March 2009 08:41 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
Copyright ©1999-2017 diyAudio
