Old 20th October 2011, 11:24 PM   #1
Default My Pearl One. Some questions
Hi guys!
This is my first post and I would like to show my Pearl One :
https://picasaweb.google.com/1150424...65708755140994
https://picasaweb.google.com/115042429352783535448
I have some questions and I want to know if anyone can help me.
At the output of the power supply, I check about 48 volts DC, is this value is correct? This voltage is it safe for the circuit?. I'm using basically the scheme of the unregulated supply (Pearl One PDF page 3, Fig 4):
A pair of Diodes 2KBP01M, capacitors (Nichicon Gold Tune, 10.000 uF), and a pair of Wima MKS4.
My R-core have an output of 30 volt but when I checked, the output have 34 volt AC.
Thanks and regards
Old 21st October 2011, 05:02 AM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
as long as your Nichicon and Wima caps , then C1-C4 are up to voltage ( say 63V ) , you're good
observe temp on Q1 , too
Papa's rule - finger - 5sec , is good enough
( save this pic - it's handy )
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 21st October 2011, 05:07 AM   #3
nar is offline nar
nar's Avatar
Originally Posted by blackdod View Post
Hi guys!
Thanks and regards
Hi Blackdod,
If your Pearl works fine there is nothing to worry about
More technically, all depends which voltage value you get after the regulation. An input of 45-46V is quite correct before reg, so your value seems fine at a first glance.
Better check voltage onboard, e.g. for example between Q1 drain and ground you should measure 29V or so. If not, the discrete regulator is likely to have a problem and you'll have to debug this
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright
Old 21st October 2011, 07:41 PM   #4
6L6 is offline 6L6  United States
6L6's Avatar
Wow! Very nice build!
I like your selector for input loading resistor.
Old 22nd October 2011, 06:55 AM   #5
Hey guys
Thanks for your answers.
Right now I'm thinking of remaking the selector to make it look a little more professional.
Today I will do my first listen to the final assembly... I hope not to have any problems.
Old 22nd October 2011, 07:10 AM   #6
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Nice. But don't link too big images, they change the reading frame and are difficult to some. I made those to attachments so they never get lost as expired links even. Also, other guys don't quote along with same images if in same page. Thanks.
Old 22nd October 2011, 07:19 AM   #7
Sorry Salas
Thanks and regards
Old 26th October 2011, 04:36 PM   #8
Hi Guys
After a few hours, I have the same problem on both plates . I heard a noise and saw that the IRF9510 was burned. I've replaced and now I have +29.5 volt regulated again after the R8. Until this point everything well.
The problem I see now is that the R17 (14 volt) and R14 (19,5 volt) I have a voltage of 29 volts!
On the other hand, in the C7, I have a value of 26 volts (I assume that this value can be considered normal), but in the C8, I checked 29 volt again.
Is it possible that ZTX450 are wrong? I do not understand how the scheme after the R14 indicates a value of 19 volt and 29 volt I always check here.
Any ideas??
Old 26th October 2011, 05:33 PM   #9
Zen Mod's Avatar
something is wrong
double check your measuring , give us exact schematic , write measured voltages on schematic .
if you're using winbooze , use paint
here it is - save this sch and open with Paint ; use red color for your numbers
Old 26th October 2011, 06:54 PM   #10
Hi
The data that I could check. They are all on PAD2 - (pin negative)
Pearl Phono questions Fitz Pass Labs 7 11th January 2009 02:36 PM
Pearl questions lykkedk Pass Labs 4 8th March 2007 02:33 PM
A couple of Pearl questions WindChill Pass Labs 3 8th June 2006 01:49 AM
Questions about Pearl..... Buhl Pass Labs 11 6th June 2005 01:16 PM
More Pearl questions Brownlow Pass Labs 4 29th September 2003 01:59 PM
Page generated in 0.10131 seconds (83.05% PHP - 16.95% MySQL) with 11 queries
