Old 22nd November 2011, 09:20 AM   #51
nar is offline nar
nar's Avatar
Originally Posted by blackdod View Post
Thanks Nar
Ok I'm clear that I should not use the Pad 4.
I take your advice and bring out a led + resistance from the V+ and Ground pads on the PSU.
For about 45 volts. Should I use a very large resistance?
Depends if you use a high efficency one or standard.
Range between 10k and 68k should be ok. For my high eff white ones I use about 137k 0,25W on 48V
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright
Old 22nd November 2011, 07:18 PM   #52
Nice Nar !!!.
OK, I have some LED High Efficiency. I will test with that value of resistance.
Old 25th November 2011, 07:44 AM   #53
Hello guys!
I added a 10K resistor to the LED and the result is very good, but when I turn off the LED takes a long time off. I guess adding greater resistance than take off.
I've been testing the masses and how best to go is as I have now (safety Earth).
On the other hand, wanted to ask if the voltage on Q8-12 zone is crucial. I have a voltage of 0.1 V in this area.
Old 25th November 2011, 09:31 AM   #54
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
nope
when LED is lit for long time , that means its connected across big cap
if you put bigger resistor , it will stay lit for even longer time
either live with it , or feed LED from AC - put diode and resistor in series
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 25th November 2011, 10:42 AM   #55
Thanks Zen,
Yes, in fact I'll have to live with it or use a diode more resistance (AC).
I am seriously thinking to change it to AC, and add a small capacitor
Old 25th November 2011, 11:20 AM   #56
Zen Mod's Avatar
you don't need capacitor
tell me AC voltage you have , which LED you want to use and I'll do calc for you
Old 25th November 2011, 01:22 PM   #57
Thanks Zen
I can use +-37 or +-18 volt DC and the LED is a WP7104QBC/G (3.3 volt/20mA)
I would like the LED turns off slowly fod this I was think on a cap
Old 25th November 2011, 02:03 PM   #58
Zen Mod's Avatar
Default LED resistor calc
say that you're going to use +/-18 ; that's 36Vac ;
say that you're going for max 3mA (plenty for any signal LED)
say that you're going for just one diode in series - that's half rectifier , so you'll have (roughly , but precise enough for purpose ) 36/2 x 1.41 volts DC after diode , with modest cap ; say that 10uF/50V is sufficient
so - we have around 25Vdc
R=U/I
R=(25-3,3)/0,003
R=21,7/0,003
R=7233 Ohms
use first standard value - say 7K5
without recalc of current with altered value , we assume that we still have near 3mA
so - dissipation in resistor is :
P=I^2 x R = 0,003^2 x 7500 = 67mW , so any small metal film resistor is good enough ( factor 3 is always min in my book)
so - secondary - just one diode - cap for smoothing - resistor - LED
easypeasy
if LED is still blinding ya from listening position , you can solve that in 3 ways :
1- turn case for 90 degs , so you can't see LED
2- glue something diffuse across LED (foil or something)
3 - increase value of resitor
Old 25th November 2011, 05:40 PM   #59
Thanks for your good reply Zen.
I keep your post, since it is very interesting and helpful.
I used the 18 volt (DC) and added thanks to your recommendation a cap 10 uF but I used a 10K resistor.
According to my calculations, the result would be: (18-3.3)/0.003= 4900 Ohm; 5K
The result is very good, turning off with a slow.
Pearl Phono questions Fitz Pass Labs 7 11th January 2009 02:36 PM
Pearl questions lykkedk Pass Labs 4 8th March 2007 02:33 PM
A couple of Pearl questions WindChill Pass Labs 3 8th June 2006 01:49 AM
Questions about Pearl..... Buhl Pass Labs 11 6th June 2005 01:16 PM
More Pearl questions Brownlow Pass Labs 4 29th September 2003 01:59 PM
Page generated in 0.10317 seconds (77.70% PHP - 22.30% MySQL) with 11 queries
