my take at (true) X input stage
Old 6th September 2003, 04:44 PM   #1
keyne is offline keyne
keyne's Avatar
Cool my take at (true) X input stage
hey all,
let me start by thanking Petter, on whose work i built.
Nelson Pass once stated in the old X100 backengieneered thread that the X1000 uses cascoded input devices "to keep the power dissipation down"..
Ok.
But i think the true reason is that you need the additional cascode to be able to truly make an X circuit. The distinguishing feature, from my point of view, is that you take feedback "from the other side". When you have only the folded cascode, as in Petters and Uli's amps, you have to feed back from the same side - so in my view these are not X amps - where's the X?
(the Aleph X has it, no need to get excited)
the "magic" resistor that couples the diff amps tails has nothing to do with it, it is just a current feedback mechanism - it is not new or anything, it's in my circuit design book actually...
Please take a look at the attached schematic.
there are a few extra resistors to make the sim converge..(R12-R15) + comp. caps 1pF each.
the X is below the source, in the middle...
I'm looking forward to your comments.
keyne
Old 6th September 2003, 05:33 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Depending on the polarity of the amplification which follows
the differential input pair, you take the feedback from either side.
Odd numbers of Comon-Source gain stages (including the diff
pair as a gain stage) use the same side, and on even they
use the opposite side for the source of feedback.
The X circuit does not require cascoding, but certainly can be
made to benefit from it, just like any other amplifier.
Old 6th September 2003, 05:40 PM   #3
tschrama is offline tschrama  Netherlands
Hi Keyne
I don't think I agree, not yet atleast ...
The Q5 and Q6 do nothing for the polarity of the voltage or current signal involved., so I don't see how they can make a difference for the feedback 'take-off points' ...
The upper nodes of Q2 and Q3 don't feature (much) voltage swing .. they are allready cascoded, allthough with a folded cascode....so a additional cascode would not make much of a difference for linearity or bandwith...
I think the additional cascodes Q5 and Q6 serve to spread the dissipation ... putting less heat stress on each of the MOSFETS..
I'll try some simmulations my self.... let's hear it from the others..
Thijs
Old 6th September 2003, 05:45 PM   #4
keyne's Avatar
Mr Pass,
thanks for your comment, i see my error now!
I've been fooled by my simulation...
Mr. Pass, so the distinguishing feature is not the "X" in the schematic, but the distortion cancellation mechanism at work, right?
Thijs, your points are correct.
I still think the additional cascode is good, though. decreases voltage over the diff pair significantly.
keyne
Old 6th September 2003, 09:09 PM   #5
GRollins is offline GRollins  United States
"X" isn't cascoding, it's just a strategy for feedback. The one requirement is for the circuit to be balanced...or at least build off of a differential. The connection (of the feedback signal) between cathodes/emitters/sources is the ticket. All else is just icing on the cake.
Cascoding is a nifty addition, but isn't essential, per se. (It's just in the patent to strike fear into the hearts of heathens and unbelievers...)
Grey
Old 6th September 2003, 11:29 PM   #6
MikeW is offline MikeW  United States
MikeW's Avatar
Nice to see a post from you Grey.
MikeW
Old 7th September 2003, 04:27 AM   #7
Apogee is offline Apogee  United States
Apogee's Avatar
Welcome back Grey!
Also very glad to see a post from you...
Please don't let the screaming monkey(s) run you off again...
Some of us out here appreciate your contributions very much... It also makes this place a bit more fun!
Hope all is well...
Best,
"If I had my life to live over again, I would have made a rule to read some poetry and listen to some music at least once a week." - Charles Darwin
Old 7th September 2003, 07:11 AM   #8
tortello is offline tortello  Italy
tortello's Avatar
Grey,
happy to see you again!
Marcello
Old 7th September 2003, 07:16 AM   #9
macka is offline macka
macka's Avatar
Grey,
Wonderful to read your posts,
macka
Old 7th September 2003, 06:44 PM   #10
The one and only
Grey is back!
my take at (true) X input stageHide this!Advertise here!
MC Input Stage Onvinyl Analogue Source 16 19th November 2007 12:59 PM
Adding a third input to a differential input stage? maudio Solid State 15 11th October 2006 02:16 AM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
Input stage Andrey Solid State 5 21st June 2002 01:32 PM
Copyright ©1999-2017 diyAudio
