Legato 3.1 balanced out to my Aleph J (Common mode DC)
Old 12th October 2011, 04:15 AM   #1
habsrock93 is offline habsrock93  Canada
Default Legato 3.1 balanced out to my Aleph J (Common mode DC)
Just wondering if the common mode DC on the outputs of the Legato(Dac output stage) would be a problem for my Aleph J. Voltage between signal ground and +/- out is 7vdc. Voltage between the +/- out is 0vdc. Would it be better just to add a coupling cap to the + in on the Aleph J? Thanks for any help. I'm really looking forward to hearing these togeather
Dave
Old 12th October 2011, 04:17 AM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
either caps or xformer
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th October 2011, 04:20 AM   #3
Wow that was a fast reply Thanks. Caps it is. On the negitive input to the Aleph J the cap is after the 22.1k resistor. Do you think I should copy that on the + side?
Dave
Old 12th October 2011, 04:31 AM   #4
Zen Mod's Avatar
caps from legato then 100K bleeders to gnd then Aleph
4u7 caps are big enough
Old 12th October 2011, 10:07 PM   #5
oneoclock is offline oneoclock  Europe
oneoclock's Avatar
Is that a possible solution?
Old 13th October 2011, 02:46 AM   #6
Is this what you mean?
Old 13th October 2011, 08:10 PM   #7
Zen Mod's Avatar
yup
Old 13th October 2011, 10:32 PM   #8
Ok, great. Thanks for the help.
Dave
Old 13th October 2011, 10:40 PM   #9
Zen Mod's Avatar
and , yes - short instead of C1
those CR cells are intended to be on Legato side ; that's why resistors are on outer side , to prevent any cap leakage/discharge during re/connecting procedure
Legato 3.1 balanced out to my Aleph J (Common mode DC)Hide this!Advertise here!
Common-mode choke before or after? neskor Power Supplies 1 19th May 2011 07:36 PM
common mode choke help milen007 Power Supplies 11 14th March 2011 04:40 AM
common-mode chokes jarthel Tubes / Valves 6 11th February 2008 03:31 PM
Aleph-X with common-mode oscillation DACMan1 Pass Labs 11 16th July 2006 02:47 PM
Common mode chokes Dr.H Digital Source 1 24th July 2002 04:47 PM
Copyright ©1999-2017 diyAudio
