Old 11th October 2011, 01:37 AM   #1
Default Threshold Stasis II help needed please
Hi Gang,
I just pulled out the Stasis II power amp from storage, about 10 years now. It was brought up to date with new caps and poly bypasses etc a few years before I put it in storage. So when I plugged it in, I powered it up through the big 200W light bulb, the light was bright at first, then dimmed to a moderate level, and the started to pulse slightly at about 1Hz. Thought it must just be that the bias wasn't quite at the level to keep it stable so I threw the switch to bypass the bulb and bang, blew the left rail fuse and popped a 1 ohm emitter resistor and 4 output devices. Oh darn I exclaimed!
Today I fixed yesterdays damage and powered it up the same way, and the same result, pulsing light bulb at about 1Hz. I used the variac this time to bring it up slow, monitoring the rail current in the fuse holder, and when the rails hit 30VDC, it jumps from .3A up to about 3.9A and the rails drop to about 25VDC. Output offset goes from .05 to about .5VDC. Any increase in rail voltage, results in drastic increase in rail current, up to about 5A is where I stopped. I checked all the small signal transistors while I had the board loose and everything looked fine. This amp has been modified for fixed bias, someone has removed the pot and put in a precision resistor to make the bias about .6A. Worked great 10 years ago when I used it regularly. I changed the electrolytics on the driver board, no difference.
So, have any of you experienced a similar problem to this? I will wait to hear from you before I tear it apart again. Any thoughts on the possible problem? I checked all the output devices and emitter resistors. Right channel is fine so I could start by comparing L-R resistances etc., swap the driver card etc..
Cheers
Paul
Old 14th October 2011, 12:54 AM   #2
The one and only
Nelson Pass's Avatar
Perhaps you would like to bring it up on the variac with a short across the
bias circuit and see who draws current.
Old 14th October 2011, 03:27 AM   #3
Hello Nelson,
Thank you so much for the reply. So you think I may still have a flakey output device in there eh? (Canadian accent noted?) Okay, will do. A quick check of voltage across the emitter R's outa do it. I would eventually like to load both channels with all new MJ15023/24 but for now, all I have in stock are MJ15003/4 so that is what I have replaced the damaged devices with. I know they are only 2Mhz parts.
I'll let you know how it goes.
I have been away from designing and playing with high end audio for 9 years now, while raising my son, but now I have been re-bitten by the audio bug. I seem to have missed a lot in those years, as far as design and semis go...SIC jfets?? I am just starting to read old posts and get caught up. A whole lot has progressed.
Cheers and thanks again for sustaining this wonderful hobby with fresh ideas!
Paul
Old 19th December 2011, 10:20 PM   #4
Well I finally got back to it today...shorted out the bias xstr, MPSA42, and brought it up slowly on the variac, and there was no current draw in the suspect channel. Rails went right up to +/- 45 VDC......then as an insentive to really dig into this amp, something in the right channel failed and THANKFULLY, I had the light bulb in series with the variac, the bulb came on full brightness and the rails dropped to +/- 5VDC. GREAT! I give up.
Nothing went pop or emitted smoke, but definately a new problem in the right channel, confirmed by pulling the rail fuse. Bloody hell..
I will have to pick up on it again later. Totally frustrating.
Anyway, that's my report. Any thoughts?
Cheers
Paul
Old 3rd January 2012, 03:20 PM   #5
Finally got back to this amp yesterday and put in 4 hours of troubleshootiung. Good news is that I fixed the right channel...it was one output shorted. What makes these random failures happen??
Resoldered all connections on the original problem left channel and cleaned up the PCB. Tried powering it up again and same thing. Won't go past +/- 28VDC rail voltage before the output stage starts drawing 3 or 4 amps. I checked the output thinking maybe osc. but it's clean. The wires are so darn short in there it's hard to power it up and get any access to the outputs, but I'll give it another try and see if I can find a flakey part. I checked all the devices when I had the channel out and they all check fine on my DVM.
I'll keep trying.
Paul
Old 3rd January 2012, 05:15 PM   #6
The one and only
Originally Posted by kilohertz View Post
I'll keep trying.
That's the ticket. When you're done you'll know a lot more than when
you started.
Old 4th January 2012, 12:11 AM   #7
Default Are new driver boards available for this amp?
Thanks Nelson,
The cranium has a little rust on it these days.... and the troubleshooting skills have faded slightly...but they are getting better as I go. I was hoping to just replace ALL the outputs with new MJ15023/24 but On-Semi lost my order. Waiting for a new shipment.
In the meantime, I'll hone my skills.
One other question, are there new driver boards, i.e. newer rev. that I could install? My amp is from 1979. I was also thinking of maybe trying to work the A40 boards into this...but I haven't looked at the A40 schematics in a while. I have 2 driver boards, stuffed and ready to use. May need higher voltage parts?? Just thinking that if the trouble is not output devices, and these input/driver boards have been modifed with new caps etc over the previous years owners, that maybe a fresh set of input boards with new parts might be an improvement. Your thoughts?
Thanks again,
Paul
Old 7th May 2012, 08:45 PM   #8
Paul, did you ever get that Stasis 2 running?
It would sure be nice if someone would make some bare driver board copies for the Stasis 2/3 amps. These board takes beating everytime you work on them. It's so easy to lift a land if you are not super careful. My Staisis 2 boards both have more than one repaired land - they could look a lot better!
The Stasis 2 is a lot of labor to work on, but these great amps deserve all the attention you can give them. You will spend many hours on the resoration, but it will be worth the effort. My guess is that once you pull the at left-bank off, if you haven't done so already, you are going to find a short somewhere - either a shorted output device, a sneeky little solder bridge, or some other "tech" mistake made in the past.
Also, ditch that non-adjustable bias fixed-resistor for a 10-turn or better trim pot. Once you have your new outout devices installed and everything is just right, you will need to tweak the bias to make it perfect.
I have restored three of these to date (two Stasis 2s and one Stasis 3) all with age related and abuse issues, two of which required all new output devices on both channels. I had great success and recommend ON MJ21195/96 devices. With the new output devices, be sure to go for some nice new emitter resistors. The old carbon-comps will be out of spec by now. Panasonic ERX series are darn good and resonably priced, and are available in all the values that you will need: ERX-3SJ1R0 Panasonic - ECG | P1.0W-3BK-ND | DigiKey.
Best of luck and keep us posted on the progress!
Forrest
Old 8th May 2012, 11:36 PM   #9
Audio Junkie
Zero Cool's Avatar
Are you sure all the driver transistors are good?? I have seen many times that when an output device fails, it will sometime take a driver transistor out with it too! If you are drawing heavy current from the AC line when you are below 30 volts on the variac, that is usually a sign of a blown output device. if you can get past 30vac and it starts drawing heavy current when you get near or just past 1/2 line voltage, that typically points to an driver transistor that has failed. and granted this is a generalization and assumes 120V unit. but it helps point to where to look.
Also watch for oscillation. I have seen amps that will start to oscillate and draw heavy line current.
Zc
It's not about what you can BUY...It's about what you can BUILD!
Threshold FET2 Series ii Schematic Needed DJ LeBaron Pass Labs 0 3rd March 2011 04:36 PM
Threshold Stasis S500 Series II amandarae Pass Labs 9 21st November 2009 05:39 PM
Threshold Stasis 2. steenoe Pass Labs 52 29th August 2007 06:59 AM
Threshold Stasis 3, too Roscor61 Pass Labs 3 20th May 2004 09:12 AM
Page generated in 0.11733 seconds (82.15% PHP - 17.85% MySQL) with 10 queries
