BA-C
BA-C
Old 11th October 2011, 06:24 PM   #21
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
BA-C
I was afraid it might be the Cathermin tube with inindium complex of +4, which would be really bad
Old 11th October 2011, 09:47 PM   #22
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Sorry out of town, so i dont have ability to add sketch. Looking at your article, Michael, the first schematic where you introduced the mosfets and bias resistors. Even though the load is on the drain, it is functioning as a transconductance amp, correct, providing only current gain. Flip the fet and make it common drain, you have a buffer who's cuurent is determined by bias. Either way, you have only current gain.
Old 11th October 2011, 10:22 PM   #23
AudioMaker.Tech
BA-C
Here's an old drawing I did. Would we expect these two circuits to behave the same?
Old 12th October 2011, 02:00 AM   #24
buzzforb's Avatar
In second schematic with no ground there re two paths for the signal, one thru fet and other thru voltage source of opposite side. Left side drain will see inverted signal while right side will see non inverted signal
Old 12th October 2011, 12:30 PM   #25
AudioMaker.Tech
BA-C
Hello, Buzz
I believe you were asking if the standalone circlotron stage has current gain, voltage gain, or both. Were you not?
Old 12th October 2011, 03:24 PM   #26
buzzforb's Avatar
Are you saying the reference to ground makes V gain possible?
Old 12th October 2011, 07:01 PM   #27
AudioMaker.Tech
BA-C
No.
I'm suggesting the lower diagram has both. You may recognize it conceptually as the output stage of The Amazing FET Circlotron.
Old 12th October 2011, 08:13 PM   #28
buzzforb's Avatar
How does the lack of ground reference change things?
Old 12th October 2011, 08:55 PM   #29
AudioMaker.Tech
BA-C
Who says it does?
Let's go at this from another angle for the moment:
Couple surface observations or questions, whichever. Single stage circlotron, operated as source followwer is basically power buffer with current output determined by bias choice. Operated as common source, it is transconductance amplifier(quasi buffer), with gain of fet determining current to load. In both cases, it is just supplying current to load, thus the need for second stage. For V gain
Why do you assert that the latter has no voltage gain?
Old 12th October 2011, 11:52 PM   #30
buzzforb's Avatar
Does the speaker serve as a load resistor? If it does, isn't the fet just feeding current to the load. Isn't the source seeing the same load as the drain with the exception of passing through the "battery"?
BA-CHide this!Advertise here!
Burning Amplifier BA-2 Variac Pass Labs 1125 1st July 2014 01:39 PM
MY FIRST BUILD BA-1 joesch1999 Pass Labs 15 15th May 2011 08:54 PM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Ba-1 Rembulan Pass Labs 0 15th May 2009 01:09 AM
Copyright ©1999-2017 diyAudio
