The Aleph Jango
The Aleph Jango
Old 29th December 2012, 11:45 PM   #81
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Ikebana!
...Shape the sound , Man!
Old 30th December 2012, 12:08 AM   #82
flocchini is offline flocchini  United States
Nice
Old 30th December 2012, 02:06 AM   #83
6L6 is offline 6L6  United States
6L6's Avatar
The Aleph Jango
One output transistor?
Old 30th December 2012, 02:30 AM   #84
buzzforb's Avatar
Nope. There are two, just hard to see. 200 ohms will not do it, so i have to use bigger pot or put resistor in series. Didnt feel like messibg with it after i couldnt get bias up, so i will finish tomorrow. All else is good, functioning as expected. Tomorrow should go quickly.
Old 30th December 2012, 04:37 AM   #85
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The Aleph Jango
Originally Posted by buzzforb View Post
Ikebana!
Looks like my bench. But neater.
Don't be afraid to use clip leads....
Old 30th December 2012, 01:13 PM   #86
buzzforb's Avatar
OK. Irritated now. Cant figure out what is wrong. Cannot bring bias up past about 1V. If I check the FE independent of the output transistors, all is fine. Attaching output transistors, I have 56V across Jfet until i bias it up and then everything levels up and I have 27V across both top and bottom fets. From there it goes nowhere. cat bring gate voltage pass about 1V. What is stealing my current? I have the negative input shorted to ground. Can get the offset close to zero, then it starts to wonder. Dont have the feedback point bypassed with cap, so ill try that to stop the wandering output.
Old 30th December 2012, 01:30 PM   #87
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
The Aleph Jango
gimme exact schm which you're using , voltage across LTP drain resistor , voltages across Rs-es in output and output offset
it's wise to start troubleshooting with just one output pair , same as 9V1 zenners between G and S of outputs (you can pull it out later)
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th December 2012, 01:31 PM   #88
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
The Aleph Jango
buzz,
maybe R27 needs to be tweaked. That's what I did with the Mini-A with R100's.
Old 30th December 2012, 01:48 PM   #89
buzzforb's Avatar
Tea,
your schematic is too small to see.
ZM,
I am using the schematic from earlier in the thread given to 6L6. Fe is fine as far as I can tell. Found a little clue when testing bjt in ACS for Vdrop. When i connected one probe to the output and one to the gate of the bjt, all the sudden bias came up. I am assuming this points to bad bjt.
Old 30th December 2012, 02:05 PM   #90
Zen Mod's Avatar
The Aleph Jango
OK , I'm here
The Aleph JangoHide this!Advertise here!
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 20 7th April 2018 11:04 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 27 11th November 2017 01:13 PM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
