1M-F5 - A 1 MHz F5 project - Page 5 - diyAudio
Old 10th June 2012, 03:55 PM   #41
triode_al's Avatar
Default The F5 and short circuits
Last week I noted the sound was bad, the sound was mono-ish. I was listening to an opera (Wagner) to study the text. After some time I rearranged the speaker (hypothesis that went through my head: more toe-in, add tilt, change alignment, maybe the recording of the CD?) and sat down again. Still...
Then later I noted a loose wire. I saw sparks coming from the plug as I twisted the wire. I must say I was driving the speakers at maximum volume.
I had a broken input plug to one of my speakers (QUAD ESL 57) - resulting in a short to case/earth. Intermittent.
Today I replaced the plug.
Of course I tested the F5 on the scope: no problem at all. Still -2 mV DC (left) and 10 mV (right ch) like when I set it up.
The F5 can withstand a short-cut even if driven hard (about 10-12 V RMS) for long times!
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 10th June 2012, 04:45 PM   #42
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
you probably have those two bjt's in place
luckily
some Greedy Boyz are leaving them out
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th June 2012, 05:08 PM   #43
triode_al's Avatar
luckily
In fact I had disconnected the current limiters a few months back - I do think it provides a bit more transparence. Note that the electrostat is something like 1-2 ohms at 20 kHZ so the speaker is ready to trigger any limiter.
What I should do though is bring the limiter out to the front panel as a LED driver. How? Connect the collector to a 10 K and a suitable LED.
albert
Old 25th October 2012, 08:28 AM   #44
triode_al's Avatar
Default F5 in turbo stage 1
In August I started to parallel my outputs.
The result is really pleasing on my demanding electrostats with 1 ohm virtual at 20 kHz . The extra power is well spent . .
I have now 3 pairs parallel, and another set will come later (is installed, not connected).
The response to sine is still great (above 1 MHz) , but a square wave with a capacitative load triggers HF instability, so I used an input high roll-off filter.
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 11:56 AM
F5 Micro (A useless but funny project) Nikon1975 Pass Labs 31 15th September 2011 02:38 PM
F5 Mamak Pass Labs 15 27th March 2011 12:21 PM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 05:23 AM
Anybody help with F5? yammy1688 Pass Labs 2 28th October 2008 03:50 PM
Copyright 1999-2017 diyAudio
