#31 |
#32 |
Jack,
Nice to see your confirmation of what I saw. I assume top is voltage, lower phase. Perfect isn't it? Interesting, you get the same 6/7 MHz bump as I (but I assumed mine was higher, but out of range anyway for my measurement), and thought: it could as well be an artifact. What output did you use? Which PCB? albert
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
#33 |
I think you can make the bump go away by matching the gate stoppers on the JFETs and MOSFETs. The original design just used a 1K resistor and tied the gates together.
I used my own PCB's -- I provisioned them so I could adjust the source resistors on the input stage for lowest THD% It turns out that the 200 ohm pot (P3) is much easier to implement. |
#34 |
We have built a differential version of the B1 Buffer. It sounds very good. Much more detail for the DIY set at
intrator.dyndns.org/Audio.html |
#35 |
In the past months I have enjoyed my F5.
At times i heard that there was some slew rate limiting. This can be heard with violins or complex symphonics or singing. Either from my Aikido preamp or from my F5. I have Quad ESL 57's, with a low impedance of 1 ohm virtual at 20 KHz. Hence my choice to implement it. But if it triggers, it hurts the ears. So I took out the limiter function of the F5 by disconnecting the collector legs of the transistors Q4 and Q6. This gave some more clarity. But not enough. So I decided to oust the Aikido. I had found that the Aikido is great for pop music and non complex material, but sort of dominated a lot of complex music like classical music. My choice fell on the SP6, for which I had made a test circuit in the past using ECC82 in the first position. I now settled on the ECC81 and 12.5 dB of amplification and this way I came up with a very dynamic line amplifier. The combo gives an infinite dynamic levels of sounds. Less than 0,01% by the way and able to output 20V RMS. It surprises me how the F5 shows all the small tinkering of the preamps, of DACs and other active components.
#36 | |
Especially interconnects ![]() Best, nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
#37 | |
thank you and cheers! |
#38 | |
Too bad when I made my distortion measurements I did not have my camera at hand. The basic schema is: audio research_SP6_schematic1.gif It took me quite some time to get it under control, I started this time with ECC83 and I ended with ECC801S. albert
#39 | |
Thanks for the update, glad to hear you are enjoying your f5 on the quads ... |
#40 |
Nice work
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
| F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 | NYCOne | Pass Labs | 123 | 29th September 2011 12:04 AM |
| F5 Micro (A useless but funny project) | Nikon1975 | Pass Labs | 31 | 15th September 2011 02:38 PM |
| F5 | Mamak | Pass Labs | 15 | 27th March 2011 12:21 PM |
| F5 Cascoded - an alternative for my interest in the Balanced F5 | NYCOne | Pass Labs | 159 | 24th March 2011 05:23 AM |
| Anybody help with F5? | yammy1688 | Pass Labs | 2 | 28th October 2008 03:50 PM |
