1M-F5 - A 1 MHz F5 project
Old 30th September 2011, 10:33 AM   #21
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Hi A.wayne,
I have some extra square waves on 8 ohms.
The amp bandwidth is from DC to 2 MHz . .
10 Hz (scope set on DC) Not bad . . .
20 Hz
50 Hz, with 50 Hz PS reaction
200 Hz (it is getting boring, they are all the same)
5.000 Hz
20 K on 8 ohm and 4 ohm
Here we see a slight overshoot that is not harmful and does not impact real life music.
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anzaï Zaïka; --> FE103 sigma TQWT
Old 30th September 2011, 10:39 AM   #22
triode_al's Avatar
I changed the feedback a few days back, by taking out the 2,7 nF caps I had across the 50 ohms resistors.
Immediately I got the much wanted 'laid back' character, easy listening.
Of course the power supply caps are now getting 'burned in' (formatted), that is positive too.
Really funny because the pole it introduced was as high as 1,2 MHz - still you can hear it clearly.
I listened to a Charlin recording (two microphone concept) and indeed the hall characteristics are good to hear. (Sorry, that is Dinglish).
In fact, the amplifier is 'disappearing'. The sound now is completely transparent.
albert
Old 8th October 2011, 03:57 AM   #23
a.wayne is offline a.wayne  United States
Sin Bin
Update Albert.... did you find the F5..? .....
Old 18th October 2011, 10:54 AM   #24
triode_al's Avatar
I've been away for some time.
On returning - - - I loved the sound, so relaxed and full of fine details. Bebel Gilberto; Charpentier sung messes pour les trépasses. Authentic voice and stage.
The characteristics that the sound has the same atmosphere regardless of the pot setting still surprises me, this means the amp can very well follow low and lowest sound levels.
A hint of highs expanding, but that recedes as 'the sound settles'.
albert
Old 22nd December 2011, 08:35 AM   #25
formula 22 is offline formula 22  El Salvador
formula 22's Avatar
albert
Please if you are able to give this schematic makes the final amplifier F5?
Since I am not much versed in electronics.
thank you
Old 22nd December 2011, 12:48 PM   #26
triode_al's Avatar
thank you
Hi Formula,
the schematics are the standard F5, though I used other output devices than the stock ones [IRF9p0920].
To cater for the Toshiba's I had to change the fixed drain resistors of the input (a bit down in value), but really not to a value the potmeter in the stock schema won't get. And the source resistors are 0.47 ohms too.
So the standard set of components will work good. And with these Toshiba's the thermistor is not needed.
Why Toshiba's: they have less capacitance (and less current) than the IRF mosfets, this helps in the bandwidth.
The (standard) set can be bought with boards and all components by the way.
albert
Old 23rd December 2011, 03:53 AM   #27
CanAm Man is offline CanAm Man  United States
Gees..... I had never considered using my F5 as a final-stage power amp for my 160-meter ham rig.....but now I'll have to reconsider...!
Old 23rd December 2011, 04:02 AM   #28
Roscoe Primrose is offline Roscoe Primrose  United States
Don't forget the bandpass filter on the output ;-)
73, N4RP
Old 23rd December 2011, 09:15 AM   #29
triode_al's Avatar
The output has to be shielded and pasband optimised (like Roscoe Primrose says) and the PS fitted with snubbers, coils etc.
In my setting there is a slight peak around 6,5 MHz, with proper layout this can be remedied. Note that the resistors are coils at these frequencies. For instance a common metalized 10 ohm resistor could rise to 100 ohm.
But the basic structure could work . . . low harmonics and low impedance is just what you will like.
Of course you saw that Papa's new SITS make great radar amplifiers - likewise these Toshiba's have been used in RF equipment too.
Old 23rd December 2011, 04:11 PM   #30
Was kinda kidding about using/abusing the F5 as a ham power amp. I've already built some 1 kw solid-state linears that are broadband--as in no tuning, for any ham band between 80 to 10 meters.
I also worked on a team that used similar SiC technologies for a large UHF (430 Mhz) phased-array radar. SiC, SiT.....amazing technologies!
1M-F5 - A 1 MHz F5 projectHide this!Advertise here!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 12:56 PM
F5 Micro (A useless but funny project) Nikon1975 Pass Labs 31 15th September 2011 03:38 PM
F5 Mamak Pass Labs 15 27th March 2011 01:21 PM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 06:23 AM
Anybody help with F5? yammy1688 Pass Labs 2 28th October 2008 04:50 PM
