Old 27th September 2011, 09:43 AM   #11
triode_al's Avatar
Default Bandwidth is everything, next to phase
And that > 1 MHz claim . . . (yes, an F5 with o n e thousand kHz) bandwidth?
Easy at 8 ohm; with 4 ohm it drops to 910 kHz. And DC is also possible. My generator goes to 0,5 Hz - this is still not -3 dB.
Surprise: A channel unloaded has a bandwidth of . . . an astonishing 2,1 MHz.
With 8 ohm it is 1,2 MHz, and with 4 ohm it is 910 kHz.
I'll gladly go for a lower bandwidth. This high bandwidth is a bit scary.
I do not have high frequency probes; I load the output with a 1,5 meter RG59 cable (300 pF) which might influence the result I see. The stray capacitance can be the reason the the peak on the screen; when going through the frequencies one does not see a high Q (maybe above 6 MHz?).
At these frequencies you will see slew rate limiting. And indeed if I run a square wave through, I will see limiting starting on the rising flank of the wave above 6/700 kHz, and soon it is a triangle.
I see a very small oscillation at 2,6 Mhz and a bigger one above 5,6 MHz (the highest my signal generator can go). This surely is due to capacitative coupling for instance of the lead wires and power supply interaction.
I connected a 2,7 nF silver mica across the 50 ohms feedback resistors: the bandwidth dropped to 650 kHz. Aklso, the unloaded square is now tightly controlled.
There is slightest ringing on the flanks (e.g. 300 kHz) more in one channel than in the other, probably dissymmetry in high frequencies.
What I did was load a 470 capacitor across the output in (2). It shows the little series of straight lines, like a little slew rate (but it can't be slew rate as I see it).
Cures:
- I added a selected pair of 2,7 nF capacitors across the 50 ohm feedback resistors, selected pairs, tight matching is needed. Doesn't solve it.
- Maybe better : use input filter, 1k2 input loaded by 400 pF (low pass about 350 kHz). But this does not solve that smallest amount of ringing.
But neither helped.
- It could be balanced by adding a separate 300 pF gate/source capacitor on the 2SJ55 (because of its lower Ciss. Would this help?
- Or by adding slight different feedback caps.
Or implementing the trick in the version 2 F5 with a feedback fine-tuning pot.
Has anybody else bothered about this?
I decided to neglect this whole issue for the moment and . . listen.
See my 2SK175/2SJ55 F5.. CS8412/SAA7220/TDA1541 ; SP-6 Light ; MC30 Super--> two stage RIAA 2SK240-ECC88/6SL7.
Old 27th September 2011, 09:57 AM   #12
triode_al's Avatar
Default Distortion measurement
Because I have a electrostatic LS with a complex load the next test is very important: will the amplifier oscillate with a capacitative load? So I connected a capacitor across the output, and later used it with a damping resistor
Just a resistor (2n7 feedback cap):
Overshoot with capacitative load, 8 ohms with 0,47 muF
This is the ringing we saw earlier too.
foto overshoot 4 ohm parallel with cap 470 nF with a series 1 ohm resistor
This is well damped.
This load can be made more complex with an inductor (i would have to look for the equivalent circuit of the Quad ESL57)
The little feedback capacitor of 2,7 nF stops the overshoot unloaded and reduces the ringing only a little bit. I would need 15 nF to really stop the ringing (I tried 21 nF but this was just a bit too much damping).
Distortion picture at 2,47 kHz
Predominant second harmonic and down near the noise floor.
Compare with Le Monstre distortion
The similar topology of Le Monstre with a cascode gave me 0,6% second harmonics. See my avatar.
Old 27th September 2011, 10:05 AM   #13
triode_al's Avatar
Attachment 242038
Attachment 242039
Attachment 242040
This load can be made more complex with an inductor (i would have to look for the equivalent circuit of the Quad ESL56)
Attachment 242041
Attachment 242042
Old 27th September 2011, 10:59 AM   #14
h_a is offline h_a  Europe
h_a's Avatar
Really nice work!
Thanks for posting!
Hannes
Old 27th September 2011, 04:27 PM   #15
ichiban is offline ichiban  United States
space charged
ichiban's Avatar
And...? How does it sound.
Old 27th September 2011, 04:41 PM   #16
triode_al's Avatar
yesterday I moved it to the living room.
First impressions:
Pleasing.
Excellent. Much detail is transmitted, in depth.
Syllables and voices are having their own character, two singers in guet are clearly distinguished. No specific sound is projected (syllables).
What also surprises me is that the character remains stable when changing volume. [I first heard that on Hypex modules].
Low register is clear, the electrostats have the tendency to sound nasal; this is not [yet] heard either.
I cannot call the sound 'laid-back'.
Old 27th September 2011, 11:06 PM   #17
space charged
ichiban's Avatar
First impressions: Excellent.
Old 28th September 2011, 06:42 AM   #18
triode_al's Avatar
Default Sound impressions
Second impression:
I was listening to Alfred Deller, accompanied by a pianoforte.
The details of a highly oversampling are now transmitted. Previously, the highs (in classical music) had the tendency to have a similar sound, now I can distinguish many high instruments and the complex notes of the instrument, also behind the players.
Differences between tracks are heard.
(Carla Bruni - on m'a dit) Small artifacts that the producer mixes in are heard, sound such as from the throat (coarse) can be heard.
Very very detailed, all due to the capacity to really dump a lot of current very fast in the electrostats.
My Meridian comes to life again!!!
Old 28th September 2011, 06:41 PM   #19
a.wayne is offline a.wayne  United States
a.wayne's Avatar
9 watts is a lot of current ....
Fantastic write up Triode_al , very good details and information, much appreciated, Anyway of posting squarewave performance in the lower bandwidth, 20hz, 1 k, 20k, 40k, 100 K for eg...
regards,
Old 29th September 2011, 07:35 AM   #20
triode_al's Avatar
The amp does sound as if it is very powerful.
The analogy in impression with the 8W Le Monstre is clear now for me. It is a Monster too: 15 W.
I can calculate the peak current (the formula is Vrms/0,7=Vp); what I did do is check what the voltage was (via scope, DC input) and that gave me around 15 V on 20 V power lines when clipping starts in, if i remember correctly, with 8 ohm. I did't check the others, but surely they are high too,
2 ohms, 7 V RMS, 25 watt (10Vp=5A peak)
4 ohms, 9 volt RMS 20 watt (13Vp, 3,2 Apeak)
- I could do is take out the current limiter 'output' and connect that to a LED via a 2-3 K resistor: if it blinks I hit my max. Great test for a lab setting.
I'll make square waves from low frequencies too but I'm afraid this will have to wait three weeks (travel ..)
albert
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 123 29th September 2011 12:04 AM
F5 Micro (A useless but funny project) Nikon1975 Pass Labs 31 15th September 2011 02:38 PM
F5 Mamak Pass Labs 15 27th March 2011 12:21 PM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 05:23 AM
Anybody help with F5? yammy1688 Pass Labs 2 28th October 2008 03:50 PM
Page generated in 0.12928 seconds (83.40% PHP - 16.60% MySQL) with 11 queries
