Thank you for your reply, however I'm confused.
First you wrote:
And then you wrote:
Now, I can build amplifiers, it isn't any hassle for me, though I don't get a kick from it either. That is, I find neither a big difficulty nor a special joy from building amps.
My only concern here is the comparison of the sound quality between the two.
Should I'd build the F4, it will be 2 monoblocks, each bridged-balanced-mono, so either one of those amps should drive well my speakers.
First you wrote:
If you want to participate the next years with the First Watt and BA-line and if you like to build amps for sure the F4 is the better choice......
And then you wrote:
I would even do it knowing, the XA line sounds three times better.....
But of course the 92db of your speakers make the decision more difficult!
92db is above avg speaker efficiency, unless you have an very large multi-driver speaker system very difficult to get a good balanced sound ...
Thanks.
My speakers are 92dB@1.7Watt. They are two-way, as balanced as the best speakers I ever heard. They are neither very easy nor very hard to drive.
I think you should organize to hear both amps yourself....!
As a matter of principle, you are correct, of course.
Practically it's impossible for me since I don't know of anyone in my country who built either F4, or, more important, 2 F4 monoblocks balanced-bridged-mono.
So, in this case I have to rely on the opinions of those who heard both amps. I heard the XA30.5 and I loved it a lot, in itself and compared (from memory) to all other amps I heard, but I never heard F4 and I think I cannot hear it, unless I'll build it. I'd love to save money, since I don't have much of it left, but more than that I'd like to get the best possible sound quality I can afford. Building 2 F4 monoblocks, for the sake of comparison, will leave me without enough money to purchase the XA.
If you can live with the 30.5, buy it.
Thanks.
I can live with it happily…
I must hurry to get rid of my last words......
First, self build F4 can vary much from the F4 Nelson sells. You know he tweaks out the optimum of the circuit, I think you could not do it......
The XA is completely tweaked.....
Write an email to TONEAudio MAGAZINE | The e-journal of analog and digital sound
And contact Jeff Dorgay he heard all the First Watt and some XA. He is friendly and will not hesitate to give you some hints more..........
Small impression for you, when he compared FW J2 with XA30 he wrote
"Comparing the J2 with my Pass Labs xA100.5 100-watt monoblocks was a study in contrast. The big amps' power advantage was obvious, and that manifested itself in sheer gravitas and a richer, fleshier tonal balance. The xA100.5 soundstage was deeper and broader, but the J2 was just as transparent. Low-level resolution and transient speed were on par with the xA100.5. And the big amp is four times as expensive as the J2. "
The J2 was my 1st choice but 15 wpc into 4 ohms would have too limited speaker choices. So I will have to buy an XA30.5. And since I have no speakers good enough for this amp I must start shopping. But you must have extremely efficient speakers to be driven by the J2. Please let me know the make and model. Thanks.I must hurry to get rid of my last words......
room size ?
if plenty , you can't go wrong with any of old big honkers , Tannoy and Altec coax preferably
some info : 6moons audio reviews: Stephæn's Altec 604 Dream Speaker
I know the feeling. When I switched speakers to Cary Silver Oak Model Ones, had to trade in my trusty First Watt M2 for a XA 30.5 in order to get sufficent power to drive the speakers.
room size ?
If you like your music to shout at you .. absolutely ...
I want to know which one sounds bigger?
The heaviest one of course ....
What about in zero gravity? Which on sounds bigger?
I can give ya 2 answers :
1-did you heard right one box ......... and right xover ?
2. do yo know how Cal W. is big ?
- Between XA30.5 and F4 sonic impressions
