Been a while - I bought the heatsinks, the PCBs and the Fets etc in 2007 - or sometime then - so now I figure it really is time to put her together....
But - yes there is always a 'but' I guess - I want to extract more power and I have seen and read the 50W Zen V9 thread - maybe my ramblings should be in that thread but maybe not as that is not quite the way I wanted to go... Given that the main devices can handle 200V and 20A - is it not feasible to just up the PSU Voltage and current capability.....and heatsinking....? WM |
#2 |
I think you can do that but you must observe first stage transistors may exceed rated voltage for those so regulate down or cascode or both. I am sure there are others that have been there done that...
Regard, El
"when you open your mind to the imposible, soon you will find the truth...." |
#3 | |
Problem is, the little LU-fet comes in such a tiny package, so that it's hard to get more than 5W or so away from it (see also original article). Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#4 | |
Thanks for the comments thus far guys...
WM |
#5 |
Hello WM, as you observed, they are rated for 24V @ 50A, but not both at the same time. If you look at the datasheet for a device, these are maximum ratings at each extreme. The important spec to look at in regards to your question is the Power Dissipation. This, along with the previous specs, determines what your transistor can handle in steady state(which Class A is).
Peace, Dave |
#6 |
Thanks Dave - I am a tube guy so this solid state foray is all new to me although I guess thats no excuse I should pay more attention to the data sheets!
Ta WM |
#7 |
Also, most ratings are at 25C. Typically, in operation, we would be running 65-95C die temp.
I've had the LU part biased at 3A and 2.5V for a year without problems.
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#8 | |
Any advances on 7.5W? I guess then that the mounting of the device and the resultant thermal resistance to the heatsink requires investigation/optimisation. WM Last edited by Winding Man; 23rd September 2011 at 06:28 PM. Reason: spelling as usual |
#9 |
I have it mounted with no isolator, directly on an anadized sink, and Arctic Silver 5 compound.
#10 | |
Does this device need to be at the same temp as the main Fets as some sort of tracking thermal compensation mechanism or can it be on its own? Thinking of a separate heat sink heat pipe approach here....? Ta WM |
| possibility of using SERVO BIAS on Zen v9. | gionag | Pass Labs | 4 | 9th October 2008 07:51 PM |
| Little (or big ?) problem with a Zen V9. | gionag | Pass Labs | 14 | 21st May 2008 05:06 PM |
| Zen V9 builder need help | sandmarc | Pass Labs | 2 | 24th February 2008 07:02 PM |
| Power supply / zen V9 | Phill | Pass Labs | 5 | 22nd December 2006 11:41 AM |
| Zen v4 vs. Zen v9 | Kashmire | Pass Labs | 3 | 28th February 2006 06:56 PM |
| Page generated in 0.10736 seconds (81.97% PHP - 18.03% MySQL) with 10 queries |
