F5X from diyAudio Boards P-F5c-2V20e
Old 20th October 2011, 06:43 AM   #21
JBL4435 is offline JBL4435  Germany
Originally Posted by EUVL View Post
It is a voltage clip.
The circuit has a gain of 6. So output is at 13.8V with 16V rails.
As expected not enough headroom left for the MOSFETs.
Since you are using 2 output pairs, you can increase rail voltage and reduce bias current per FET while keeping dissipation per FET below 32W.
I would try 20V 1.6A per FET as a start.
Patrick
Thanks Patrick
I thought about that but I use 22V Rails and 1.3A per FET.
Can you explain how you get the 6dB gain? With 6dB I get 4.4V out with 2.2V in. Wasn't it 15dB?
Old 20th October 2011, 06:44 AM   #22
Originally Posted by NYCOne View Post
This is how I built one:
Building a World-Class Cascoded Balanced XF5 on a Budget
I used 1K and 100K as NP did in the original and have no problems.
Thanks for the help but this was solved a few posts before. 1k and 33.2k
Old 20th October 2011, 07:12 AM   #23
EUVL is offline EUVL  Europe
Gain of 6, not 6dB (gain of 2).
The closed loop gain of a feedback amp is given by (Rfeedback + Rshunt) / Rfeedback.
In this case, Rfeedback = 50R, Rshunt = 10R.
So gain = (50+10)/10 = 6.
Patrick
Old 20th October 2011, 07:33 AM   #24
Patrick
I've got this wrong. Thank you for clearification.
Any idea why I get this clipping? With +/- 22V Rail I should be safe.
Old 20th October 2011, 07:35 AM   #25
Your output voltage should not come closer than say 4V to the rail voltage if you want to avoid clipping.
The MOSFETs do not have sufficient Vds to operate properly.
Patrick
Old 20th October 2011, 07:59 AM   #26
Patrick
I understand that, but I'm missing a few Volts
Output with 2,3V in and gain of 6 (15,5dB) is 13,8V. With 22V Volt rail....
My PS is ultra stable. 800VA Transformer 2x18V, CLC with 2x99.000 uF, 2x 2,2mH/0,12Ohm.
Old 20th October 2011, 08:16 AM   #27
You need to show an output waveform for the clipping for us to understand your problem.
Patrick
Old 20th October 2011, 08:30 AM   #28
Patrick
OK, I'll make several pics.
Old 20th October 2011, 07:33 PM   #29
Default Measurements and Waveform 1kHz 8Ohm
Amp info:
Vrail +/- 21.8V
Ibias 0.6V across 0.47 Ohm 1.3A 2 parallel output Fets Total Bias 2.6A
I out of PS measured 5.4A
NOT X-ed yet.
1. 8 Ohm 2.5Vin 0.5%THD right before clipping
2. 8 Ohm 2.6Vin 1.5%THD start of clipping
3. 8 Ohm 2.8Vin 4.5%THD clipping
Old 20th October 2011, 07:36 PM   #30
Default Measurements and Waveform 1kHz 4Ohm
1. 4 Ohm 2.3Vin 0.6%THD right before clipping
2. 4 Ohm 2.5Vin 3.5%THD start of clipping
3. 4 Ohm 2.8Vin 7.5%THD clipping
F5X from diyAudio Boards P-F5c-2V20eHide this!Advertise here!
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 08:48 PM
Potential Other Group Buys related to EUVLs F5X heinz1 Group Buys 456 2nd March 2014 02:16 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 07:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 05:20 PM
Unique or odd uses for the diyAudio CCS boards Geek Tubes / Valves 1 12th December 2006 03:45 PM
