F5X from diyAudio Boards P-F5c-2V20e
Old 20th September 2011, 02:56 PM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by JBL4435 View Post
Look at the inverted left part of the schematic.
They are already crossed
you got me there
1 "Kiste" Beer if you show me the input resistors in that schematic
naah .... there aren't any ;
but you know that you must have them
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th September 2011, 02:57 PM   #12
Zen Mod's Avatar
Output resistors?
what with them ?
Old 20th September 2011, 03:02 PM   #13
JBL4435 is offline JBL4435  Germany
Originally Posted by Zen Mod View Post
what with them ?
Output to ground resistors 33 to 68 ohms to stabilize relative dc offset.
Are they helpful in this design?
Old 20th September 2011, 03:10 PM   #14
Zen Mod's Avatar
you already have them - look at feedback net
they have same function .
Old 20th September 2011, 03:19 PM   #15
EUVL is offline EUVL  Europe
But not when you float the X, dear Choky.
I personally would put 220R 1W to Gnd at both outputs.
But feel free to experiment.
No need to challenge Heinz1 for eine Kiste Bier.
I did not put the input resistors on the schematics, not even on the main PCB.
They are the same as in Nelson's single ended F5.
So I only posted the parts that needed to be changed.
Thought it was trivial.
Patrick
Old 20th September 2011, 03:23 PM   #16
Oh, BTW, there is at least one very good reason why the proper F5X board is superior than 2x single ended F5 board for this build.
I let you think about it first.
It has to do with the power supply.
Patrick
Old 20th September 2011, 03:29 PM   #17
Thank you!
No!
Old 19th October 2011, 09:22 PM   #18
Default Clipping Q1/Q2 ??
Is it possible to drive Q1/Q2 into clipping?
When testing the Boards with 2 output pairs into 4 ohms (not yet x-ed) I get clipping at 2.2 to 2.3V input. With this input I get around 50W into 4 ohms. No improvement over the version with 1 output pair.
This clipping appears independent of the values of the current limit circuit. I can even leave the circuit out.
Old 20th October 2011, 04:34 AM   #19
It is a voltage clip.
The circuit has a gain of 6. So output is at 13.8V with 16V rails.
As expected not enough headroom left for the MOSFETs.
Since you are using 2 output pairs, you can increase rail voltage and reduce bias current per FET while keeping dissipation per FET below 32W.
I would try 20V 1.6A per FET as a start.
Patrick
Old 20th October 2011, 05:25 AM   #20
NYCOne is offline NYCOne  United States
This is how I built one:
Building a World-Class Cascoded Balanced XF5 on a Budget
I used 1K and 100K as NP did in the original and have no problems.
F5X from diyAudio Boards P-F5c-2V20eHide this!Advertise here!
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential Other Group Buys related to EUVLs F5X heinz1 Group Buys 456 2nd March 2014 01:16 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
Unique or odd uses for the diyAudio CCS boards Geek Tubes / Valves 1 12th December 2006 02:45 PM
