Between F4 and F5
Between F4 and F5
Old 26th November 2011, 03:05 PM   #21
KatieandDad is online now KatieandDad  United Kingdom
KatieandDad's Avatar
My F4 and the Pumpkin is just a sheer delight to listen to. So musical and so engaging. My B&W 683s aren't the easiest things to please but the F4 does it perfectly.
Old 26th November 2011, 03:49 PM   #22
timbarnes is offline timbarnes  United States
timbarnes's Avatar
Originally Posted by Russellc View Post
Making sure I understand here, you are running the BA-3 right into F4, kind of like some have done with SE 45 triode amps?
Russellc
My configuration is as follows:
  1. First Sound passive "preamp" does source switching and volume
  2. BA-3 with its own power supply is used as preamp gain stage
  3. F-4 unmodified provides current amplification
Click the image to open in full size. Click the image to open in full size.
Townshend Rock III, Hagerman Bugle 2, Naim CD5i, RPi Volumio, MiniDSP, Elliot P101, IRS2092, Parham Pi Sevens & Pi Three
RC Preamp (in progress), Pass BA-3 and F4, DIY Silver cables, Open Baffle BOFU, DIY subwoofer, GainClone, o2 Headphone Amp
Old 26th November 2011, 04:10 PM   #23
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Originally Posted by NicMac View Post
Any way to combine a BA-3 with F4?
I am starting down this exact path!
http://www.diyaudio.com/forums/pass-...innings-d.html
Old 26th November 2011, 05:03 PM   #24
There seems to be a confusion between the F4 and the Aleph 4. They are VERY different beasts.
My Aleph 4 is an absolutely STUNNING 100W / Channel Class A BEAST
Old 26th November 2011, 05:42 PM   #25
Russellc is offline Russellc  United States
Between F4 and F5
OK, looks like the BA-3 is minus its output stage, and kind of a smaller transformer for its power supply? what are the rcas for on the BA-3?
Russellc
Old 26th November 2011, 05:58 PM   #26
buzzforb's Avatar
Same as any preamp. Don't get caught up in FE name and think of it as any old preamp. BA output is nothing more than stripped F4 as ZM said.
Old 26th November 2011, 09:26 PM   #27
Between F4 and F5
Timbarnes,
OK staring at the board pic in the diy store and your pic, I believe the inside set of RCAs are the inputs and the outside set are the outputs? So I figure the passive pre/selector device goes into the inputs and the outputs are feeding F-4, no?
Last questions concern power supply, appears to be some Panasonic caps, assuming 50 volt models, cant make out size in pics resolution. Transformer also appears smaller than would be the case for the BA-3 as a power amp, and it appears you have a board of rectifiers there for rectification.
Could you give some specs on these power supply parts? I assume a less stiff supply is needed when using BA-3 as a preamp sort of capacity. this appears to be a great way to do F-4, driving with a passive pre even!
Since the volume is controlled by the passive unit in front of the BA-3 "pre", I suppose it sits like it does as a "power amp", no volume control on it, only constrained by what is fed to it via the passive's volume pot?
Thanks in advance for any tips on this set up!
Russellc
Old 26th November 2011, 10:50 PM   #28
timbarnes's Avatar
Timbarnes,
That's right. I just treat it as a gain stage.
Actually the caps are 35V, which isn't quite enough, but no explosions so far...
My understanding of the BA-3 appears to differ from yours a bit: I think of it as a front-end gain stage that can be paired with various output stages, including BA-1, BA-2, or F4. In any case, that's how I'm using it.
The power transformer is about 50VA, I think at 24V, which is too high really. 18V or maybe 20 would be better. I use a CRC filter as Nelson suggests for his power amps, and I'm sure the caps (22,000uF) are complete overkill. But they were left over from a bulk buy for the F4, so I used what I had.
The rectifier is a leftover board from a gainclone I built ages ago.
Since the volume is controlled by the passive unit in front of the BA-3 "pre", I suppose it sits like it does as a "power amp", no volume control on it, only constrained by what is fed to it via the passive's volume pot?[
I wouldn't describe it as a "power amp", because it really only provides voltage gain. All the power is provided by the F4. I would describe the BA-3 as the active part of my preamp, where the gain and switching are provided by the passive control unit. In a more "normal" implementation, the BA-3 would be combined with the switching and volume control in a single box with its own power supply - then it would be indistinguishable from a preamp.
I could just as easily connect the output of the BA-3 to any power amp (although I might have too much gain). Before I had the BA-3 I used a JBOZ in the same way, and before that a pair of 5532s.
Tim
Old 26th November 2011, 11:41 PM   #29
Between F4 and F5
Thank-you for your clarity on this project. I have a Pumpkin Kit in the wings, but I like this idea of getting the necessary gain for F-4 use better....although I of course will eventually try both!
Russellc
Between F4 and F5Hide this!Advertise here!
matched Fets for your F1, F4, F5, Aleph J... h_a Swap Meet 290 11th April 2017 12:59 AM
First Watt F4 ,F5, F6, F7, F8 ? MikeW Pass Labs 10 6th June 2015 07:56 PM
POLL: Which is your fave Pass design ? F3, F4, F5, AJ vizion Pass Labs 96 14th June 2012 09:55 PM
Pass F4, F5 and Motif amps joda Swap Meet 2 24th December 2010 10:16 AM
(matched) Fets for your F4, F5, Aleph J... h_a Swap Meet 14 18th February 2010 04:45 PM
Copyright ©1999-2017 diyAudio
