Sorry, but I could not find a recent Pass Labs thread associated with heatsinks, so here goes.
I recently purchased a pair of fan-shaped aluminum heatsinks on eBay from a U.S. supplier, for $55 + free shipping. They are massive aluminum. The seller quotes a 0.74 degree C/W spec, but I suspect that may be conservative. They may be a little "light" for an F5 build, but you'all may find them useful in other Class A designs. (I know it's probably heatsink "overkill", but I'll be using these in a Class D chipamp.) The mounting surface for the semi-conductors/components is almost mirror-like (very nice construction). The seller's ad says he has more. Here's the info, if you'all are interested: eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices ...and no--the seller isn't my brother or uncle, or cousin...... |
#2 |
pair for one F5 channel , with plenty of bottom clearance
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
Bottom clearance - no saggy bottoms around here.. A breath of air from a slow fan might make those heat sinks very A-worthy.
#4 |
#5 |
I think someone sold you a polished engine block.
#6 |
And they're HEAVIER than aluminum cylinder heads, for a small-block Chevrolet....!
P.S.--I'd agree..... with some light forced air movement around these, they ought to be very impressive. I'm using some reduced-speed fans on my F5 (with the large Conrad heatsinks), and my biggest challenge is getting the MOSFETs up to temp...... |
#7 | |
EDIT: never mind. i found it. 0,74. maybe. it depends onon the temp of the heatsink. you want 25celsius above ambient? 3pr channal will do it
soon to be: papa's Class A all the way Last edited by AudioSan; 16th September 2011 at 09:33 PM. |
#8 |
From the eBay seller:
I do have many other lengths (up to 6ft) so if you tell me the aproximate size your looking for I can see what I currently have available. If you'd like an exact length I can accomodete that as well but there is a cutting fee that would have to be covered. It's a fee that I have to pay and I'd just pass that amount along. I have several already cut, exactly like you received except for the length, in the 4", 6", 7" and 11" ranges. I'd be happy to give you a good deal on any of them. I also have many other profiles (shapes) in stock so if there is a preference for shorter or wider or whatever; let me know and I can send you a drawing of the closest match. Regarding the power rating, the 0.74 C/W rating was my personal testing. The industry standard for that part is closer to 0.7 C/W. -------------- I've asked the eBay seller for his "non-eBay" Email address; when I get it, I'll post it for you'all, in case you want further communication with this seller. |
#9 |
AudioSan, and all......
The dimensions on these specific heatsinks are a 3-3/8" x 5" base, with fins rising 5-3/8" from the milled surface of the base. These are my actual measurements of my samples. |
| Open baffle candidate??? | sandyhooker | Full Range | 6 | 25th June 2009 09:11 PM |
| ab class heatsink dimensioning | morpheus82 | Solid State | 6 | 21st April 2005 09:35 PM |
| N.E.W A-60 Class A heatsink | vsr123 | Pass Labs | 10 | 19th May 2004 07:45 PM |
| Is an AD8066 would be a good candidate for Class A biasing ? | dtm1962 | Digital Source | 0 | 3rd May 2004 10:03 PM |
| Page generated in 0.10732 seconds (83.04% PHP - 16.96% MySQL) with 11 queries |
