Old 10th September 2011, 04:55 PM   #1
Default F2J power supply voltage??
I am gathering parts to build a F2J clone and I was wondering if it is ok to use higher voltage without to much modification to the original circuit. I have an big(600va) old transformer with one 30vac secondary winding, collecting dust...
Use regulated supply, to get the voltage down, but how much?
Unwind the transformer?
Or buy a new one?
Old 10th September 2011, 05:48 PM   #2
The one and only
Nelson Pass's Avatar
The original is 23V DC, achieved with an 18V AC secondary. You can go a bit
higher without issues, but I think 30V AC should probably be dropped down
a bit. You could make a CRC filter in the supply that loses 10V on the
resistor.
Old 10th September 2011, 05:59 PM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
that amp is worth some trouble to make it right
either unwind , or buy new one
2 x250VA for dual mono ; 2x18Vac secondaries
or 500VA for both channels , 4x18Vac secondaries
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 11th September 2011, 03:51 AM   #4
For an F2J, won't 2 secondaries be sufficient ?
2 x 250VA for dual mono ; 1x18Vac secondaries (each)
or 1 x 500VA for both channels , 2x18Vac secondaries
(Edit: or did mean the number of wires ?)
Old 11th September 2011, 07:33 AM   #5
Thank you very much for the quick replies.
But, what would be the disadvantage using only one secondary winding?
Anyone happen to have some spare pcb by the way? Or i will just do p2p...
Kjetil
Old 11th September 2011, 07:34 AM   #6
Zen Mod's Avatar
@Lazy....
mea culpa !
off course that you are right
I meant on another FW amp , which use symm. PSU
in any case - VA numbers are still valid
Old 15th September 2011, 04:14 PM   #7
OK, Thanx Zen !
@Holminator: the disadvantage would be cross talk between left and right channel. I'd guess with a CCS, this is a minor disadvantage though
Now I'm wondering ...- all things being equal: if we have 2 secondaries in total in each case: is there any advantage at using one 250VA with 1 secondary per channel vs 1 x 500VA with 2 secondaries for both channel ? (like due to coupling of windings between each other) ?
power supply voltage dscottguitars Instruments and Amps 8 16th August 2011 08:48 PM
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
Power Supply B+ voltage? losacco Tubes / Valves 9 6th December 2010 09:11 PM
high voltage power supply leemajcool Power Supplies 3 5th August 2007 11:40 AM
Comprimize of power supply voltage cm961 Chip Amps 3 16th June 2003 08:35 PM
Page generated in 0.08447 seconds (74.52% PHP - 25.48% MySQL) with 10 queries
