Passlabs envelope design - high-grade outline and very easy at the same time.
I like this design much more than all the other (especially than the often to find profile enclosure systems with bad quality metric threads in the aluminium). The envelope of these high quality models consist basically of 10 elements: - front-panel, - rear-panel, - 2x side panels so as - bottom cover and - top cover - so as - four connecting devices therefore, fitting with metric threads, each from four surfaces (see attached image). What is the colloquial term of this connecting devices? Are this connecting device even made by default (thus available as standart part) or purely custom-made? Thank you for your advices. Last edited by tiefbassuebertr; 5th September 2011 at 10:11 PM. |
#2 |
The one and only
They are machined from aluminum for us.
We have used these sort of corner blocks since 1991. The refined chassis you see now is the work of Desmond Harrington, who joined the company in 1996. You may recognize his style from the glory days of Krell.
#3 | |
Seems there's no standard term or off-the-shelf parts available (at least from McMaster-Carr...) |
#4 |
You can find it under square rod's in distributor catalogs that has engineering materials, I know RS stocks a few types, yo uwould need to cut, drill and tap it though.
#5 |
"Rod" is a geometrical term for solid cylinder, and >technically< the type of bar stock known as 'rod' is always round. The bar stock we want here is square bar (or rectangular bar).
#6 |
RS sell square bar
And me was thinking to have had an original idea |
#7 | ||
Obviously such corner blocks are also available as standart parts and not only as custom made devices - check out this by google: "MA0586" (e. g. MA0586-16, MA0586-15, MA0586-17 resp. 0586-15 or 0586-16) MA-0586-16 - Corner Block-24.65mm | RCBits.com.au Repair Parts-Heli Wholesaler Midland Helicopters Ltd HeliSprs_MAFury55 Knock-Down K/D Fittings 1 http://www.boononline.com/products_pictures/0586-16.jpg www.boononline.com MA0586-16 Corner Block 24.65mm MA0586-16 Corner Block 24.65mm Experience RC The source material for Corner blocks without incised threads: Square Rod Stock (available as current meter merchandise) Flat Stock, Al, 6061, 1/4 x 3 In, 3 Ft - Aluminum Blanks, Flats, Bars, Plates, and Sheet Stock - Aluminum - 2EYZ6 : Grainger Industrial Supply or square rod's Flat Stock, Al, 6061, 1/4 x 3 In, 3 Ft - Aluminum Blanks, Flats, Bars, Plates, and Sheet Stock - Aluminum - 2EYZ6 : Grainger Industrial Supply Tube Adapters : TMR Customs, Custom Fabrication Components for Offroad Vehicles or square bar (resp. rectangular bar) http://www.metals4u.co.uk/products.asp?cat_id=19 And some URLs arround the other mentioned terms: corner cleat (in German: angle-iron or mounting brackets) Large Cleat, Double Slot Corner Cleat, Ironmongery, Height Barriers Park Gate, Small Gates, Belcher S Letter Boxes Service Provider From Uk C.P. Belcher(Welding) Ltd. - products mounting block (Eyebolt-Mounting Block) http://www.heightsafety.com.au/image...ting-Block.jpg Z-Laser BM Magnetic mounting block.Cutting Edge Lasers - lasers, laser levels and measuring equipment. Last edited by tiefbassuebertr; 11th September 2011 at 10:45 AM. |
#8 |
Unless you need quite a few of those, it will take longer to buy them and pick them up at the post office, than to just make them yourself.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#9 | |
My bad, my english dropped me for a second there, I meant to not use the word tube, as those are hollow, and then I came up with rod instead of bar.... You could also order from clickmetal for smaller pieces. http://www.clickmetal.co.uk/Angle-Ty...ars/c-1-16-11/ Its about 2GBP for 1/4inch per 20cm. Last edited by digits; 11th September 2011 at 12:33 PM. |
#10 | |
| Guitar preamp envelope follower | iaia976 | Analog Line Level | 4 | 8th February 2010 02:46 PM |
| High-rails Passlabs amplifier design ? | Bønna | Pass Labs | 19 | 24th April 2009 12:55 PM |
| Passlabs preamp as headphone amp- need help | needtubes | Headphone Systems | 3 | 16th February 2004 09:30 PM |
| 10,000ufd/100V computer grade electrolytics | rickp | Swap Meet | 3 | 26th January 2004 09:30 PM |
| High Grade Midranges | Myren | Multi-Way | 9 | 17th December 2001 04:42 AM |
| Page generated in 0.11722 seconds (82.34% PHP - 17.66% MySQL) with 11 queries |
