Early clipping with JX Amp
Old 5th September 2011, 09:08 AM   #1
JBL4435 is offline JBL4435  Germany
Default Early clipping with JX Amp
Dear Forum Members and Pass DIY Experts
I did some measurements with my new JX Amp this weekend and see lower power and earlier clipping than I expected.
The JX is designed after my erlier XA Amp which was designed with the AXE1.2 spreadsheet for app. 70W at 7-8 ohms. XA amp had 3 output pairs (12 IRFP240 per channel)
Power supply info
Rail Voltage: 18,3V
99.000uF CLC
Bias "old" XA is 3.3A
AC current gain app 60%
The JX works with the same ps, AC gain (R24=714 ohm) and bias.
It is build with the boards from peter (see picture)
It is build with 2 output pairs (8 IRFP240 per channel)
The JX starts clipping MUCH earlier. It delivers only 49 Watts into 8 ohms at 1kHz with 1% THD whereas the XA delivered 68 Watts into 8 ohms at 1kHz with 1% THD.
The 4 ohm values are 25 Watts into 4 ohms at 1kHz with 1% THD for the JX whereas the XA delivered 51 Watts into 4 ohms at 1kHz with 1% THD.
All THD measurements are made with a HP Audio Analyzer.
My thought was that the JX can roughly be calculated as the XA. What is wrong here?
Old 5th September 2011, 09:18 AM   #2
Default 4 Ohm graphs
Here are the 4 Ohm graphs
Old 5th September 2011, 09:24 AM   #3
Default CCS set
I adjust the bias with R27 being a 10k resistor with a 50k pot in series.
See picture (ZenMods idea for adjusting CCS)
Old 5th September 2011, 10:15 AM   #4
Default Power supply, JFet
Correction:
The PS is not 99,000 uF CLC but 198,000 uF CLC
The jfet I use is the 2SJ109BL (app 8mA Idss)
Old 5th September 2011, 11:04 AM   #5
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
naah ......
that's invented by some much cleverer than Mighty ZM
probably somewhere in Merlin's time
regarding earlier clipping ..... by (previous ) "XA" you mean exactly same output topology as in JX ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th September 2011, 11:05 AM   #6
Originally Posted by Zen Mod View Post
naah ......
Yes, but you brought it into the thread at the right time to the right position
Any idea what's going on with my amp?
Old 5th September 2011, 11:08 AM   #7
Zen Mod's Avatar
I edited previous post , while you were typing yours
Old 5th September 2011, 11:12 AM   #8
"Old" XA had 3 output pairs (12 IRFP240 per mono block)
"New" JX has 2 output pairs (8 IRFP240 per mono block). I didn't want to use 3 pairs as I'm not sure the 2SJ109 can drive it.
PS (Rail voltage) is the same, Total Bias is the same
Old 5th September 2011, 11:16 AM   #9
Zen Mod's Avatar
well - OLG of amp is this way much smaller ( jfet have lesser xconductance than mosfets in LTP , and now you have 2/3 of output xconductance )
what you need is to recheck AC Bias of Aleph CCS
search on forum , post by Papa .
Old 5th September 2011, 12:21 PM   #10
It is checked. 62%
The clipping is unsymetrical if this helps. Negative half clips earlier.
So you mean the JX isn't scaleable to 80W like the XA?
Where do I loose the voltage/current?
Do you think it might help to parallel 2 jfets?
Early clipping with JX AmpHide this!Advertise here!
amplifier clipping early gruni Solid State 3 15th March 2010 12:57 AM
Recovery from clipping, soft clipping hahfran Solid State 49 23rd February 2010 01:03 AM
Help on Jordan JX-150, JX-92s, G2si three way design Padel Multi-Way 28 14th December 2004 08:17 PM
